R50/53 newman ph2 camshaft issue?
Old Nov 16, 2025 | 05:28 PM
gratefulone's Avatar
gratefulone
I just received a new Newman PH2 Cam for my R53. On inspection it looks like it has a few imperfections. Should I be concerend or are these normal since it's a modified cam?
Attached Thumbnails newman ph2 camshaft issue?-675240a8-ccdf-4bd9-8cb1-2fa29d0c9bd5.jpg   newman ph2 camshaft issue?-30ea16e6-0d7a-4223-bbb4-debeed107f2e.jpg   newman ph2 camshaft issue?-fafe3f25-dbf3-4973-818f-57ed13ee0166.jpg
Old Nov 17, 2025 | 09:01 AM
cooper48's Avatar
cooper48
Looks like poor quality control. I would be more concerned with the scratches on the lobe in your third attached photo. Send it back.
Old Nov 17, 2025 | 12:24 PM
gratefulone
Thank you for the info. The I cleaned the lobes and they look pristine. The vendor said that that the imperfections are from the cam casting process and won't interfere with anything. Should I just sand off those imperfections carefully or leave them?
Old Nov 18, 2025 | 06:54 AM
cooper48's Avatar
cooper48
Shouldn't matter one way or the other as long as you're careful and don't remove additional lobe material to negatively affect balance.
Old Nov 18, 2025 | 08:35 AM
ssoliman's Avatar
ssoliman
assuming its balanced i would leave them.
i dont know enough to make a judgement regarding the scratches
Old Nov 18, 2025 | 08:37 AM
gratefulone
The scratches were just dust fibers. Thank you bot hfor your advice!
Old Nov 22, 2025 | 04:35 PM
gratefulone
Hi All, I just finished the cam install and had a question before I start the engine. I noticed when I installed the intake lifters it would not sit flush because one of the lifters for cylinder 3 was pressing up against one of the cam lobes on the Newman PH2 cam I installed. I slowly tighthen the 5 bolts gardually from inside to out and was able to make it sit flush. Same thing happened with the exhaust lifters, this time for both lifters on cylinder 4. I believe this is normal due to the Newman PH2 cam profile. Is my thinking correct? If not what do you think is causing an issue? I've attached a video of the intake side lifter assembly. Thank you
File Type: mov
Old Nov 22, 2025 | 05:11 PM
gratefulone
I was able to turn the egine over 3 times via the crank pulley. My plan is to pull the fuel pump fuse and then crank the engine over 3 times to build oil pressure and then cycle the inginiton to the number two position to prime the fuel pump (I also replace the fuel injector o-rings), put a jumper on the battery and try to start the car. Any concerns? Thanks!
Old Nov 22, 2025 | 07:18 PM
ghostwrench's Avatar
ghostwrench
Curious. Did you install new rockers with the new camshaft?
Asking because I have WMW camshaft to install and I am inclined to replace all the rockers with it so they wear together.
Old Nov 22, 2025 | 07:26 PM
gratefulone
No I re-used mine. How do you like your Milltek header? I just installed mine, but haven't really driven the car much.
Old Nov 23, 2025 | 06:24 AM
ghostwrench
It has been a little more than 1000 miles and 2 months and I am happy with it. Still no Check Engine light from the high flow cat and I think the somewhat increased exhaust volume has a really good tone. My wife, who doesn't drive the car much, drove it the other day and commented that she really likes how it sounds, so I call that a win! We are in our early 50's so that comment from a woman of that age put a smile on my face! I take that as a green light to put a cat back exhaust on her daily driver.
Old Nov 23, 2025 | 04:35 PM
gratefulone
Thanks for the info. Sounds like it will be perfect for my use case!
Old Nov 23, 2025 | 05:43 PM
gratefulone
Was able to start the car and it runs fine. Time for my Adrian tune next. Thank you all!
BoomerDC
Jun 16, 2022 06:42 PM
Sc0ut1
Oct 29, 2019 07:01 AM
spillman
Dec 15, 2005 07:02 PM
