R50/53 2006 R50 Sunroof Leak?
Old Nov 23, 2025 | 04:31 PM
CRC's Avatar
CRC
About 10 days ago, I noticed water on the driver's side dash and a damp spot in the corner of the headliner. Aha, I thought, the sunroof drain tube is leaking. Then I remembered that I had this problem a few years ago and fitted a new drain tube, secured with cable ties.
So, I took everything apart so as to drop the corner of the headliner to check if somehow the drain tube had come loose, the rubber had perished (unlikely), etc. All seemed okay so I poured a bottle of water down the drain tube to check for leaks. The water flowed out okay leaving a puddle on the garage floor. So, no blockage in the drain tube. I felt all around the drain tube but could not feel any water. Also, I didn't notice a damp spot on the headliner.
Any ideas where the water could be coming from.
Old Nov 23, 2025 | 07:21 PM
ssoliman's Avatar
ssoliman
try the hose test. spray an area, starting from low to high. check for leaks.
move a bit higher, repeat and check for leaks.
move a bit higher...
sounds like the drain but I guess it could be the windows?
Old Nov 24, 2025 | 12:22 PM
+1 This is common in the older MINI when they get clogged or the rubber tube falls off.
https://www.northamericanmotoring.co...of-drains.html
Old Nov 24, 2025 | 02:40 PM
CRC's Avatar
CRC
I will definitely try it but when I poured a bottle of water down the drain it went thru to the floor, and I didn't see any on the inside of the headliner.
meyerside
Apr 17, 2024 05:47 AM
Stinch
Jan 18, 2015 10:17 PM
Sergej
Aug 12, 2012 09:06 PM
Tylermtech
May 25, 2011 09:06 AM
rwolfie40
Chicago MINI Motoring Club
11
Apr 17, 2010 11:36 AM
