Please help identifying this coolant part.
Old Oct 23, 2025 | 09:15 PM
BCRob's Avatar
BCRob
Can you help identify this leaking part in my coolant system of my 2012 Base Mini Cooper? Not sure what sensor it is (assuming it’s a sensor).
Thanks,
Rob
Old Oct 24, 2025 | 03:50 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
That is your coolant temp sensor. Unfortunately, there was a service bulletin back in the day that replaced it with a coolant hose and thermostat revision so they are no longer available. You can try pulling it and replacing the seal on it. But, the only other option would be to replace the hose and thermostat with the newer version, which isn’t a trivial task…
Old Oct 24, 2025 | 03:52 AM
BCRob's Avatar
BCRob
Thank you :-)
Old Oct 24, 2025 | 08:25 AM
Yep
https://www.northamericanmotoring.co...is-sensor.html
https://www.northamericanmotoring.co...ntryman-s.html
Old Oct 24, 2025 | 08:40 AM
BCRob's Avatar
BCRob
Thank you. I’ll try the black sealant first… much appreciated.
Old Oct 28, 2025 | 01:10 PM
Ok you are welcome.
Michaelh57
R60/R61 Stock Problems/Issues
Apr 27, 2020 04:18 PM
r53Chad
Oct 7, 2019 06:25 PM
Minnie.the.Moocher
Apr 2, 2019 10:50 PM
stevepsd
Feb 17, 2016 12:29 PM
Gmoney97
Nov 17, 2013 10:53 AM
