R56 FRM2 Coding Problems
Old Sep 24, 2025 | 05:03 PM
silentsnow31802's Avatar
silentsnow31802
I recently purchased a 2010 Mini that has had the FRM replaced at some point.
My fog lights will not turn on with the dash switch (but do turn on through INPA) and my turn signals do not self cancel. I am assuming this is FRM programming related.
I have also noticed the FRM does not have my VIN programmed to it.
I have been trying to get the VIN in the FRM changed for a few days now and cannot get it to stick.
I have tried Tool32 with job c_fg_schrieben and it looks like it succeeds but if I try and read back the VIN I get no result.
I have also tried flashing the FRM through WinFPK which also looks like it succeeds but the VIN does not change.
I believe the FRM uses the FRM_70 not FRM_86. At least this is what INPA tells me it is.
I have also tried to connect with NCSExpert but it get a VIN is faulty error which I believe is because of the FRM having the wrong VIN.
Can someone please help guide me in the right direction here?
Old Sep 25, 2025 | 03:14 PM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
Not sure, but the FRM information below (image) may help you. I found the information here.
Also, go to the RealOEM website and enter the last seven digits of your VIN. Then navigate to Vehicle Electrical System > CONTROL UNIT, FOOTWELL MODULE. Check whether your Mini requires a FRM3 rather than a FRM2.
Old Sep 29, 2025 | 08:59 AM
silentsnow31802
Thank you! Also sorry for my late reply. Was out of town.
Looks like I do need a FRM3. I'll see if I can find one and go from there.
Old Sep 29, 2025 | 09:14 AM
Maybe, maybe not
Community Builder
Good luck with the fix!
Old Sep 29, 2025 | 09:25 AM
silentsnow31802
I found a picture of the original that was in the trunk when I bought the car. Luckily I took this pic before throwing it out. I assumed it was bad and the original but wasn't 100% sure. Now I know...
Old Sep 29, 2025 | 10:12 AM
Maybe, maybe not
Community Builder
Seems like you will soon solve this puzzle.
Old Sep 29, 2025 | 12:12 PM
Yep, that supersedes to this one. 61353456051 ==> 61356827072
https://www.ecstuning.com/Search/Sit...h/61353456051/ which is https://www.ecstuning.com/Search/Sit...h/61356827072/
Old Oct 18, 2025 | 03:52 PM
silentsnow31802
Thank you all for the help.
It took 2 tries to find a working one but I landed on a FRM3 part number 61353456952.
Also turns out my software install was bad. Had troubles with the new FRM at first but I knew this one was good. Found a new software download and copied the config over without issue.
One step closer to getting this thing back on the road.
Clockwork
R55 :: Clubman Talk (2008+)
Sep 12, 2022 07:48 AM
TISGOD
Electrical
Jan 20, 2021 09:37 AM
John_theCapn
Dec 8, 2017 06:39 AM
2tonebb6
Oct 5, 2016 01:58 PM
TiggerGTO
Electrical
24
Apr 19, 2012 03:27 PM
