Electrical R52 Lights on etc, no key in ignition
Hi everyone,
I’ve been having a verrrry strange issue with my R52 for the last few months.
Car’s been in the shop since December trying to figure this out....
Around November I started having issues with a dead battery when I’d go out to start the car. So I installed a brand new battery.
My girl looks at the driveway camera at 2am and notices that my lights are on. I go out to turn them off and the dash is all lit up as well and I can’t turn anything off by inserting the key and switching that on and off. I start the car, drive around the block, park - and the engine won’t turn off when I take the key out. It does eventually shut down on its own and the dash / exterior lights eventually turn off as well.
This happens constantly until I finally take the car in to the shop where it’s been ever since.
This mechanic is VERY competent, and very well known in the South Florida Mini community.
He’s checked my BCU, checked for water in the passenger footwell - including pulling out my interior and checking all wiring, said everything looks fine.
He’s stumped.
I’ve found posts with similar issues but never really a solution.
Here’s a video showing exactly what’s happening, note the engine running when I pull key out:
Anyone have this issue and what did you do to fix it?
Thank you for any help you can give!
T
He’s stumped.
T
In my opinion you must change the BC module.Is defective.Can buy an used one and recode it with NCS Expert.If the diagnosis can't see the BC module, for sure is a bad one.If can recognize the BC, just save the BC config and transfer all data in a used BC with NCS Expert.Anyway that is a low cost solution.An used one is around 70$ on ebay.
BC module initialization This can be solved by default coding with NCS Expert.
FH_FAHRERTUER_TIPP_AUF
aktiv
FH_BEIFAHRERTUER_TIPP_AUF
aktiv
DWA
nicht_aktiv
SCHAERFEN/ENTSCHAERFEN
schloss_und_fernbedienung
PANIK_MODUS
nicht_aktiv
FUNK_INNENRAUMSCHUTZ
aktiv
QUIT_AKUST_SCHAERF
nicht_aktiv
QUIT_AKUST_ENTSCH
nicht_aktiv
QUIT_OPT_ENTSCH
aktiv
QUIT_OPT_SCHAERF
nicht_aktiv
NEIGUNGSGEBER
aktiv
ALARM_AKUSTISCH
aktiv
BEDIENSTELLE_BFT
nicht_aktiv
FH_ABSCHALTKRITERIUM
wert_03
FH_NACH_TUERE_AUF
nicht_aktiv
FUNKTION_CABRIO
aktiv
EINKLEMMSCH_REVERSIEREN
nicht_aktiv
ALARM_AKUSTISCH_LANG
nicht_aktiv
IB_BEI_KL.R_AUS
aktiv_mit_kl.58
KALTUEBERWACHUNG_NSL
nicht_aktiv
KALTUEBERWACHUNG_NSW
aktiv
SCHEINWERFERREINIGUNG
aktiv
CC_BREMSLICHT
aktiv
ALARM_OPT_ABBLENDLICHT
nicht_aktiv
ALARM_OPT_FERNLICHT
nicht_aktiv
ALARM_OPT_WARNBLINKER
aktiv
LEUCHTWEITENREG_AUTOM
aktiv
VERRIEGELN_AUT_AB_X_KM/H
aktiv
WISCHERINTERVALL
wert_01
ZV_SELEKTIV
nicht_aktiv
CLT_AKTIV_IM_CRASH_MODE
nicht_aktiv
CODIERUNG_ERFOLGT_1
codierung_erfolgt
ENTSICHERN_CENTERLOCK
nicht_aktiv
INNENLICHT_AN_MEHRFACH_ZV
aktiv
KOMFORTSCHLIESSUNG_FB
nicht_aktiv
STANDRUECKSCHALTUNG
nicht_aktiv
VERRIEGELN_XKM/H_SENDER_1
aktiv
VERRIEGELN_XKM/H_SENDER_2
aktiv
VERRIEGELN_XKM/H_SENDER_3
aktiv
VERRIEGELN_XKM/H_SENDER_4
aktiv
VERZUG_PANIK_MODUS_0.2_S
wert_01
VERRIEGELN_AUT_NACH_2_MIN
aktiv
VERRIEGELUNGSSCHWELLE
16_km/h
ABFRAGEZEIT_AHM
wert_01
ABSCHALTUNG_UNTERSPG
wert_01
ENTPRELLZAHL_FEHLERERK
wert_01
KALTUEBERWACHUNG_AL
nicht_aktiv
KALTUEBERWACHUNG_FL
aktiv
ABSTAND_HOLD_NORMAL_MODE
wert_02
HALB/VOLLSCHRITT
halbschritt
HYSTERESE_STARTBEDINGUNG
wert_02
KALTUEBERWACHUNG_BLK_HI
nicht_aktiv
KALTUEBERWACHUNG_BLK_VO
nicht_aktiv
SCHRITTABSTAND_GRENZE
wert_01
SCHRITTABSTAND_STARTPHASE
kennlinie_01
TEMPERATUR_GRENZE
grad_-20
ABS_MIN_STELLUNG_2
wert_02
GED_FL_ALS_DRL
nicht_aktiv
HEIMLEUCHTEN
wert_02
SCHRITTE_STELLUNG_0
wert_01
wert_02
SCHRITTE_STELLUNG_1
wert_04
SCHRITTE_STELLUNG_2
wert_04
TAGFAHRLICHT_ECE
aktiv
U_POTI_STELLUNG_0
wert_01
U_POTI_STELLUNG_1
wert_01
U_POTI_STELLUNG_2
wert_01
BLS_PRUEFEN
nicht_aktiv
ABSENKUNG_10_KM/H
wert_02
ABTASTRATE_DYN
wert_01
ABTASTRATE_TREND
wert_01
ABWEICHUNG_TREND
wert_01
ANHEBUNG_175_KM/H
wert_02
ANZAHL_QUICK_RUNDEN
wert_01
AUSWERT_GRADIENT
aktiv
AUSWERT_PROP_ABWEICHUNG
aktiv
DAUER_DYN_NACHFUEHRUNG
wert_01
DEF_LWR_SENSOR_HI
wert_01
DIFFERENZ_MSP_DYN_STAT
wert_01
EPSILON_DELTA_A
wert_02
EPSILON_DELTA_AV
wert_02
GRADIENT_SCHLECHTWEG
nicht_aktiv
HOEHENWEG
wert_01
KALTUEBERWACHUNG_KZL
aktiv
KENNLINIE_LWR_SENSOR_HI
wert_02
KENNLINIE_LWR_SENSOR_VO
wert_01
LEUCHTWEITENREG_DYNAM
aktiv
LEUCHTWEITENREGELUNG
aktiv
LWR_NEIGUNG_KONSTANTE
wert_02
LWR_VORZEICHEN
wert_01
M_TELEGRAM
nicht_aktiv
MIN_STEIGUNG_VZ_WECHSEL
wert_01
MINDESTANZAHL_VZ_WECHSEL
wert_01
MITTELUNGSINTERV_DYN
wert_01
MITTELUNGSINTERV_TREND
wert_01
MITTELUNGSINTERV_VZ_WECHS
wert_01
NACHLAUF_SCHLECHTWEG
wert_01
OFFSET_LWR
wert_02
PWM_ANSTEUERUNG_KZL
wert_01
REFERENZL_MODE_TEIL1
wert_01
REFERENZL_MODE_TEIL2
wert_01
REFERENZL_SCHRITTABSTAND
wert_01
REFERENZL_SCHRITTANZAHL
wert_01
SAETT_TIMER_SCHLECHTWEG
aktiv
SCHW_GRAD_BESCHLEUNIGUNG
wert_01
wert_02
SCHW_GRAD_BREMSEN
wert_01
wert_02
SCHW_GRADIENT_SCHLECHTWEG
wert_01
SCHW_PROP_ABWEICHUNG
wert_01
wert_02
SCHW_TREND
wert_01
SP_MOTOR_BEWERTEN
aktiv
SP_MOTOR_F_EINTRAG
aktiv
SP_MOTOR_STOP
aktiv
TREIBER_BEWERTEN
aktiv
TREIBER_F_EINTRAG
aktiv
VMAX_BESCHLEUNIGUNG
wert_01
VMAX_BREMSEN
wert_01
VMIN_BESCHLEUNIGUNG
wert_01
VMIN_BREMSEN
wert_01
WARMUEBERWACHUNG_KZL
aktiv
ZEIT_KALT_PULSE
wert_01
ZEIT_KALT_PULSE_QUICK
wert_01
ZEIT_KALT_RUNDEN
wert_01
ZYKLUS_KALT_RUNDEN_QUICK
wert_01
AC_AUTO
aktiv
AC_BASIC
nicht_aktiv
AUXILIARY_LAMP_ENABLE
nicht_aktiv
BOOT_RELEASE_ENABLE
aktiv
CLUTCH_OFF
wert_01
CLUTCH_ON
wert_01
DAYLIGHT_RUN_POWER
wert_01
DEFAULT_EXT_AMBIENT_TEMP
nicht_aktiv
DIPPED_BEAM_NAS
nicht_aktiv
ENTRIEGELN_B_MOTOR_STOP
aktiv
FOG_DISABLE_WITH_TRAILER
aktiv
FRONT_FOG_NAS
nicht_aktiv
HALTEN_FB_OEFFNEN_TASTE
ohne_funktion
HFS
aktiv
HFS_HIGH_TEMP_TIME
wert_01
HFS_LOW_TEMP_TIME
wert_01
HR_HIGH_BAT_THRESHOLD
wert_01
HRW_HIGH_TEMP_TIME
wert_01
HRW_LOW_BAT_THRESHOLD
wert_01
HRW_LOW_TEMP_TIME
wert_01
INDICATE_DURING_HAZARD
aktiv
KEY_DISARM
aktiv
KOMFORTOEFFNUNG_SCHLOSS
nicht_aktiv
MAN_WISCHEN_IM_WASCHPROG
aktiv
NO_SOFT_ON_OFF
nicht_aktiv
PARKING_LIGHTS
nicht_aktiv
POWER_WASH_OFF_TIME
wert_01
POWER_WASH_ON_TIME
wert_02
REAR_WIPER_CONTINUOUS
nicht_aktiv
REMOTE_CONTROL
aktiv
SENSOR_REGEN
aktiv
WINDOW_AUTO_UP_DRIVER
nicht_aktiv
WINDOW_AUTO_UP_PASS
nicht_aktiv
WINDOW_INCH_AUTO
aktiv
WINDOW_SUNROOF
nicht_aktiv
WIPER_BOOT_INHIBIT
nicht_aktiv
WIPER_CAM_DELAY
wert_01
WIPER_NO_PROG_REAR_WASH
nicht_aktiv
WIPER_REAR_CAM_DELAY
wert_01
WIPER_WASHER_START_TIME
wert_01
WISCHER_GESCHW_ABHAENGIG
aktiv
FRONT_FOG_ENABLE
aktiv
HEADLAMP_LEVEL_TYPE
lwr_intern
INERTIA_SW_FITTED
nicht_aktiv
REAR_FOG_ENABLE
aktiv
ABSCHALTUNG_VERBRAUCHER
aktiv
AL_AUS_BEI_KL_50
nicht_aktiv
ANHAENGERMODUL_PWM_WERT
wert_01
ANLAUFSTROMBEGRENZ_MEMO
nicht_aktiv
ANSTEUERZEIT_MOTOR_HK
wert_01
ANSTEUERZEIT_ZV_AGGREGATE
plus_0ms
ANZAHL_NACHWISCHZYKLEN
ANZAHL_SPRITZIMPULSE
ANZAHL_WASCHBET_ZUR_SRA
AUSSENTEMP_SENSOR
aktiv
BEDIENSTELLE_FT
aktiv
BETR_STD_NICHT_LOESCHEN
aktiv
BETRMODI_DEAKT_KL15_EIN
nicht_aktiv
BLINKIMPULS_WARNBLK
nicht_aktiv
BLOCKIERSCHUTZ_AKT_XXS
wert_01
BLOCKIERSCHUTZ_HI_AKT_XXS
wert_01
CABRIO_FH_VO_ZEIT_AUF
1000ms
CABRIO_FH_VO_ZUERST_AUF
aktiv
CABRIO_FH_VO_ZUERST_ZU
nicht_aktiv
CENT_LOCK_MGL_VO_TUER_AUF
nicht_aktiv
CODIERUNG_ERFOLGT_0
codierung_erfolgt
CODIERUNG_ERFOLGT_4
codierung_erfolgt
CODIERUNG_ERFOLGT_5
codierung_erfolgt
CODIERUNG_ERFOLGT_6
codierung_erfolgt
CODIERUNG_ERFOLGT_7
codierung_erfolgt
DIFFERENZ_ANLAUF_BLOCK
wert_01
DRITTE_TASTE_SENDER
wert_01
DWA_HEKKLEPPENKONTAKT
aktiv
EINKLEMMSCH_VORNE
nicht_aktiv
EINSTEIGHILFE
nicht_aktiv
EINSTIEG_FH_ZU_VER_SPERRE
nicht_aktiv
EKS_GEDRUECKT/OFFEN
wert_01
EKS_OFFEN/UNTERBRECHUNG
wert_01
EKS_REVERSIERZEIT_ZUS
wert_01
ENTR_HKL_MGL_WENN_VER
nicht_aktiv
FE_MODE_JEDOCH_MIT_FB
nicht_aktiv
FERNBEDIENUNG_1
nicht_aktiv
FERNBEDIENUNG_2
nicht_aktiv
FERNBEDIENUNG_3
nicht_aktiv
FERNBEDIENUNG_4
nicht_aktiv
FH_ABSCHALTEN_BLOCK_AUF
wert_01
FH_ABSCHALTEN_BLOCK_ZU
wert_01
FH_ANHEBEN_TRANSPORTMODE
aktiv
FH_BLOCKABSCHALT_TUER_AUF
wert_01
FH_HINTEN_TIPP_AUF
aktiv
FH_HINTEN_TIPP_ZU
nicht_aktiv
FH_INIT_TRANSPORTMODE
nicht_aktiv
FH_SPEICHERN_TRANSPORTMOD
aktiv
FH_TIMEOUT
8sec
FL_AUS_BEI_KL_50
aktiv
FRISCHLUFT_PARKPOSTITION
aktiv
FZV_TIMEOUT
wert_02
HFS_ON_TIME_LOW_VOLTAGE
wert_01
HKL_SPERREN_BEI_ZS
nicht_aktiv
HRW_NUR_BEI_GESCHL_VERDEK
aktiv
HRW_ON_TIME_LOW_VOLTAGE
wert_01
HUB_VERZOEGERUNG_FH_VORN
0ms
IB_AUS_NACH_X_SEKUNDEN
20s
IB_BEI_KL.R_AUS_OHNE_58G
ohne_bedingung
IB_EIN_16MIN_WENN_STANDLI
nicht_aktiv
IB_EIN_BEI_HKK/HSK
aktiv
IB_EIN_N_KL_58G_MAX_1MIN
zwei_minuten
IB_EIN_SCHLOSS_ENTRIEGELN
aktiv
KALTUEBERW_AUS_BEI_KL_50
aktiv
KALTUEBERWACHUNG_BL
nicht_aktiv
KALTUEBERWACHUNG_BL_MI
nicht_aktiv
KALTUEBERWACHUNG_SL_H
aktiv
KALTUEBERWACHUNG_SL_V_I
aktiv
KALTUEBERWACHUNG_ZSW
nicht_aktiv
KEIN_HECKWISCHER
kein_heckwischer
KOMFOEFFNEN_SPERRE_KEY_IN
aktiv
KOMFORTOEFFNEN_FB_O_FH_HI
aktiv
KOMFORTOEFFNEN_FB_O_SHD
nicht_aktiv
KOMFORTOEFFNUNG_CLT
nicht_aktiv
KOMFORTSCHLIE_FB_O_FH_HI
nicht_aktiv
KOMFORTSCHLIE_FB_OHNE_SHD
nicht_aktiv
KOMFORTSCHLIESUNG_SCHLOSS
aktiv
KRB_WIE_VA/HKK_STATT_IB
aktiv
LAENDERVARIANTE_ECE
aktiv
LAENDERVARIANTE_US
nicht_aktiv
MAUT_N_ABBRECH_N_TUER_AUF
nicht_aktiv
MIN_PWM_TASTVERHAELTNIS
wert_01
MIT_AHM
aktiv
MIT_MFL
aktiv
MIT_OPT_ALARM
aktiv
MIT_WISCHER_SERVICEPOS
nicht_aktiv
N_VER_B_ERN_GESCHW_SCHWEL
nicht_aktiv
NSW_AUS_BEI_KL_50
aktiv
OFFENE_FENSTER
nicht_aktiv
OHNE_HRW
nicht_aktiv
OHNE_INRS_BESTAETIGUNG
mit_bestaetigung
OHNE_SCHEIBENABSENKUNG
mit_absenkung
POTISTELLUNG_IN_77H
wert_01
PWM_ANSTEUERUNG_AL
wert_02
PWM_ANSTEUERUNG_BL
wert_01
PWM_ANSTEUERUNG_BLK_HI
wert_01
PWM_ANSTEUERUNG_BLK_VORN
wert_01
PWM_ANSTEUERUNG_FERNLICHT
wert_01
PWM_ANSTEUERUNG_IL
wert_01
PWM_ANSTEUERUNG_NSL
wert_01
PWM_ANSTEUERUNG_SL_H
wert_01
PWM_ANSTEUERUNG_SL_V_I
wert_01
PWM_ANSTEUERUNG_VA
wert_01
QUIT_AKUST_SCHAERF_KLAPPE
nicht_aktiv
QUIT_OPT_ANZAHL_ENTSICHRN
QUIT_OPT_ANZAHL_SICHERN
QUIT_OPT_SCHAERF_KLAPPE
aktiv
QUITIMP_SICHERN/ENTSICHER
aktiv
ROVER_FZV_STATT_BMW
bmw_fzv
SCHEIBE_ABSENKZEIT
wert_01
SCHEIBENABSENK_OHNE_EKS
ohne_eks
SCHWELLE_GEBLAESESENSOR
wert_01
SCHWELLE_MERHK_KS
wert_01
SCHWELLE_MERHK_OL
wert_01
SENSOR_REGEN_N_STUFE2
stufe_2
TAUSCH_AUSGANG_NSL_NSW
nicht_aktiv
TRA_MODE_JEDOCH_MIT_FB
nicht_aktiv
UEBERSPGSABSCHALTUN_AL/FL
aktiv
UMLUFT_PARKPOSTITION
nicht_aktiv
VA1/VA2_AUS_NACH_X_MIN
16_min
VERL_ALARMZEI_WAEHR_ALARM
nicht_aktiv
VERZ_FRWISCHER_N_WASCHANF
wert_01
VERZ_HKWISCHER_N_WASCHANF
wert_01
VERZOEGERUNG_S56A_D_AUS
wert_01
VERZOEGERUNG_SHD_KOE
sofort
VERZOEGERUNG_SHD_KS
sofort
WARMUEBERWACHUNG_AL
aktiv
WARMUEBERWACHUNG_BL
aktiv
WARMUEBERWACHUNG_BL_MI
aktiv
WARMUEBERWACHUNG_BLK_HI
aktiv
WARMUEBERWACHUNG_BLK_VO
aktiv
WARMUEBERWACHUNG_FL
aktiv
WARMUEBERWACHUNG_NSL
aktiv
WARMUEBERWACHUNG_NSW
aktiv
WARMUEBERWACHUNG_SL_H
aktiv
WARMUEBERWACHUNG_SL_V_I
aktiv
WARMUEBERWACHUNG_ZSW
nicht_aktiv
WE_MODE_JEDOCH_MIT_FB
nicht_aktiv
WISCHER_RUECK_GESCHW
wert_01
WISCHER_VOLLEND_KLR_AUS
keine_vollendung
WISCHERINTERVALL_HECK
wert_01
XENON_TEST
aktiv
XENON_TIME
wert_01
XENON_TIMEOUT
wert_01
ZEIT_TUER/SCHLIESSZEIT
wert_01
ZEIT_WASCH_M/O_HKWISCHER
wert_01
ZSW_AUS_BEI_KL_50
aktiv
KS_ABSCHALTUNG_AL
nicht_aktiv
KS_ABSCHALTUNG_BL
aktiv
KS_ABSCHALTUNG_BL_MI
nicht_aktiv
KS_ABSCHALTUNG_BLK_HI
aktiv
KS_ABSCHALTUNG_BLK_VO
aktiv
KS_ABSCHALTUNG_FL
nicht_aktiv
KS_ABSCHALTUNG_IB
aktiv
KS_ABSCHALTUNG_KRB
nicht_aktiv
KS_ABSCHALTUNG_KZL
nicht_aktiv
KS_ABSCHALTUNG_NSL
aktiv
KS_ABSCHALTUNG_NSW
nicht_aktiv
KS_ABSCHALTUNG_SL_H
nicht_aktiv
KS_ABSCHALTUNG_SL_I
nicht_aktiv
KS_ABSCHALTUNG_VA
aktiv
KS_ABSCHALTUNG_ZSW
nicht_aktiv
ALARM_MUW_SENSOR
aktiv
CABRIO_FH_KOMP_AUF_MIT_FB
aktiv
CABRIO_FH_NICHT_ZU_MIT_FB
aktiv
KALTUEBERWACHUNG_BL_MI_2
nicht_aktiv
KALTUEBERWACHUNG_IB2
aktiv
LWR_POS2
wert_03
LWR_POSR
wert_03
MIT_AUSSTIEGSLEUCHTE
aktiv
MIT_NSL_RECHTS
nicht_aktiv
PWM_ANSTEUERUNG_IB2
wert_01
WARM_WITH_OL_BTS716
nicht_aktiv
WARMUEBERWACHUNG_IB2
aktiv
ZENTRAL_FH_SCHALTER
aktiv
ZENTRAL_FH_SCHALTER_VERZ
wert_01
BLS_POLL_TIME
wert_02
ZENTRAL_FH_SCHALTER_MAUT
aktiv
FLC_FAILSAFE
aktiv
FLC_OHNE_RLS
nicht_aktiv
MIT_FLC
aktiv
MIT_FLC_SCHALTER
aktiv
MIT_WWA
aktiv
WWA_MOTOR_AN_ZEITZELLE
wert_01
WWA_MOTOR_AUS_ZEITZELLE
wert_01
WWA_SENSOR_ABTASTUNG
wert_02
ANLIEFERKODIERUNG
nicht_aktiv
KALTUEB_AUS_BEI_SCG
aktiv
KOMFORT_OEFFNEN_VERZ
wert_01
wert_02
KOMFORT_SCHLIESSEN_VERZ
wert_01
MAUT_NUR_BEI_MOTOR_AN
nicht_aktiv
TILT_SIRENE
aktiv
TM_ENTR_HECKKLAPPE
aktiv
WWA_LED_KL15_DAUER
wert_01
WWA_LED_MOT_DAUER
wert_01
WWA_LED_TAKT_AUS
wert_01
WWA_LED_TAKT_EIN
wert_01
WWA_LED_TRIG_DAUER
nicht_aktiv
WWA_LED_WASCH_DAUER
wert_01
TM_FOLLOW_ME_HOME
nicht_aktiv
TM_POSLIGHT
nicht_aktiv
AUTOM_ER_KEY_OFF
nicht_aktiv
EXT_BEREICH_KURZHUB
wert_01
KURZHUB_KOMPL_ABSENKZEIT
aktiv
MAXWERT_FH_POS_HB
wert_01
MAXWERT_FH_POS_LB
wert_01
aktiv
aktiv
DWA
nicht_aktiv
PANIK_MODUS
nicht_aktiv
aktiv
QUIT_AKUST_SCHAERF
nicht_aktiv
QUIT_AKUST_ENTSCH
nicht_aktiv
QUIT_OPT_ENTSCH
aktiv
QUIT_OPT_SCHAERF
nicht_aktiv
NEIGUNGSGEBER
aktiv
ALARM_AKUSTISCH
aktiv
BEDIENSTELLE_BFT
nicht_aktiv
wert_03
FH_NACH_TUERE_AUF
nicht_aktiv
FUNKTION_CABRIO
aktiv
nicht_aktiv
nicht_aktiv
IB_BEI_KL.R_AUS
aktiv_mit_kl.58
nicht_aktiv
aktiv
aktiv
CC_BREMSLICHT
aktiv
nicht_aktiv
ALARM_OPT_FERNLICHT
nicht_aktiv
aktiv
aktiv
aktiv
WISCHERINTERVALL
wert_01
ZV_SELEKTIV
nicht_aktiv
nicht_aktiv
CODIERUNG_ERFOLGT_1
codierung_erfolgt
nicht_aktiv
aktiv
nicht_aktiv
STANDRUECKSCHALTUNG
nicht_aktiv
aktiv
aktiv
aktiv
aktiv
wert_01
aktiv
16_km/h
ABFRAGEZEIT_AHM
wert_01
wert_01
wert_01
KALTUEBERWACHUNG_AL
nicht_aktiv
KALTUEBERWACHUNG_FL
aktiv
wert_02
HALB/VOLLSCHRITT
halbschritt
wert_02
nicht_aktiv
nicht_aktiv
wert_01
kennlinie_01
TEMPERATUR_GRENZE
grad_-20
ABS_MIN_STELLUNG_2
wert_02
GED_FL_ALS_DRL
nicht_aktiv
HEIMLEUCHTEN
wert_02
SCHRITTE_STELLUNG_0
wert_01
wert_02
SCHRITTE_STELLUNG_1
wert_04
SCHRITTE_STELLUNG_2
wert_04
TAGFAHRLICHT_ECE
aktiv
U_POTI_STELLUNG_0
wert_01
U_POTI_STELLUNG_1
wert_01
U_POTI_STELLUNG_2
wert_01
BLS_PRUEFEN
nicht_aktiv
ABSENKUNG_10_KM/H
wert_02
ABTASTRATE_DYN
wert_01
ABTASTRATE_TREND
wert_01
ABWEICHUNG_TREND
wert_01
ANHEBUNG_175_KM/H
wert_02
ANZAHL_QUICK_RUNDEN
wert_01
AUSWERT_GRADIENT
aktiv
aktiv
wert_01
DEF_LWR_SENSOR_HI
wert_01
wert_01
EPSILON_DELTA_A
wert_02
EPSILON_DELTA_AV
wert_02
nicht_aktiv
HOEHENWEG
wert_01
aktiv
wert_02
wert_01
aktiv
aktiv
wert_02
LWR_VORZEICHEN
wert_01
M_TELEGRAM
nicht_aktiv
wert_01
wert_01
wert_01
wert_01
wert_01
wert_01
OFFSET_LWR
wert_02
PWM_ANSTEUERUNG_KZL
wert_01
wert_01
wert_01
wert_01
wert_01
aktiv
wert_01
wert_02
SCHW_GRAD_BREMSEN
wert_01
wert_02
wert_01
wert_01
wert_02
SCHW_TREND
wert_01
SP_MOTOR_BEWERTEN
aktiv
SP_MOTOR_F_EINTRAG
aktiv
SP_MOTOR_STOP
aktiv
TREIBER_BEWERTEN
aktiv
TREIBER_F_EINTRAG
aktiv
VMAX_BESCHLEUNIGUNG
wert_01
VMAX_BREMSEN
wert_01
VMIN_BESCHLEUNIGUNG
wert_01
VMIN_BREMSEN
wert_01
aktiv
ZEIT_KALT_PULSE
wert_01
wert_01
ZEIT_KALT_RUNDEN
wert_01
wert_01
AC_AUTO
aktiv
AC_BASIC
nicht_aktiv
nicht_aktiv
BOOT_RELEASE_ENABLE
aktiv
CLUTCH_OFF
wert_01
CLUTCH_ON
wert_01
DAYLIGHT_RUN_POWER
wert_01
nicht_aktiv
DIPPED_BEAM_NAS
nicht_aktiv
aktiv
aktiv
FRONT_FOG_NAS
nicht_aktiv
ohne_funktion
HFS
aktiv
HFS_HIGH_TEMP_TIME
wert_01
HFS_LOW_TEMP_TIME
wert_01
wert_01
HRW_HIGH_TEMP_TIME
wert_01
wert_01
HRW_LOW_TEMP_TIME
wert_01
aktiv
KEY_DISARM
aktiv
nicht_aktiv
aktiv
NO_SOFT_ON_OFF
nicht_aktiv
PARKING_LIGHTS
nicht_aktiv
POWER_WASH_OFF_TIME
wert_01
POWER_WASH_ON_TIME
wert_02
nicht_aktiv
REMOTE_CONTROL
aktiv
SENSOR_REGEN
aktiv
nicht_aktiv
WINDOW_AUTO_UP_PASS
nicht_aktiv
WINDOW_INCH_AUTO
aktiv
WINDOW_SUNROOF
nicht_aktiv
WIPER_BOOT_INHIBIT
nicht_aktiv
WIPER_CAM_DELAY
wert_01
nicht_aktiv
wert_01
wert_01
aktiv
FRONT_FOG_ENABLE
aktiv
HEADLAMP_LEVEL_TYPE
lwr_intern
INERTIA_SW_FITTED
nicht_aktiv
REAR_FOG_ENABLE
aktiv
aktiv
AL_AUS_BEI_KL_50
nicht_aktiv
wert_01
nicht_aktiv
wert_01
plus_0ms
AUSSENTEMP_SENSOR
aktiv
BEDIENSTELLE_FT
aktiv
aktiv
nicht_aktiv
BLINKIMPULS_WARNBLK
nicht_aktiv
wert_01
wert_01
1000ms
aktiv
nicht_aktiv
nicht_aktiv
CODIERUNG_ERFOLGT_0
codierung_erfolgt
CODIERUNG_ERFOLGT_4
codierung_erfolgt
CODIERUNG_ERFOLGT_5
codierung_erfolgt
CODIERUNG_ERFOLGT_6
codierung_erfolgt
CODIERUNG_ERFOLGT_7
codierung_erfolgt
wert_01
DRITTE_TASTE_SENDER
wert_01
aktiv
EINKLEMMSCH_VORNE
nicht_aktiv
EINSTEIGHILFE
nicht_aktiv
nicht_aktiv
EKS_GEDRUECKT/OFFEN
wert_01
wert_01
wert_01
nicht_aktiv
nicht_aktiv
FERNBEDIENUNG_1
nicht_aktiv
FERNBEDIENUNG_2
nicht_aktiv
FERNBEDIENUNG_3
nicht_aktiv
FERNBEDIENUNG_4
nicht_aktiv
wert_01
wert_01
aktiv
wert_01
FH_HINTEN_TIPP_AUF
aktiv
FH_HINTEN_TIPP_ZU
nicht_aktiv
nicht_aktiv
aktiv
FH_TIMEOUT
8sec
FL_AUS_BEI_KL_50
aktiv
aktiv
FZV_TIMEOUT
wert_02
wert_01
HKL_SPERREN_BEI_ZS
nicht_aktiv
aktiv
wert_01
0ms
20s
ohne_bedingung
nicht_aktiv
IB_EIN_BEI_HKK/HSK
aktiv
zwei_minuten
aktiv
aktiv
KALTUEBERWACHUNG_BL
nicht_aktiv
nicht_aktiv
aktiv
aktiv
nicht_aktiv
KEIN_HECKWISCHER
kein_heckwischer
aktiv
aktiv
nicht_aktiv
KOMFORTOEFFNUNG_CLT
nicht_aktiv
nicht_aktiv
nicht_aktiv
aktiv
aktiv
LAENDERVARIANTE_ECE
aktiv
LAENDERVARIANTE_US
nicht_aktiv
nicht_aktiv
wert_01
MIT_AHM
aktiv
MIT_MFL
aktiv
MIT_OPT_ALARM
aktiv
nicht_aktiv
nicht_aktiv
NSW_AUS_BEI_KL_50
aktiv
OFFENE_FENSTER
nicht_aktiv
OHNE_HRW
nicht_aktiv
mit_bestaetigung
mit_absenkung
POTISTELLUNG_IN_77H
wert_01
PWM_ANSTEUERUNG_AL
wert_02
PWM_ANSTEUERUNG_BL
wert_01
wert_01
wert_01
wert_01
PWM_ANSTEUERUNG_IL
wert_01
PWM_ANSTEUERUNG_NSL
wert_01
wert_01
wert_01
PWM_ANSTEUERUNG_VA
wert_01
nicht_aktiv
aktiv
aktiv
ROVER_FZV_STATT_BMW
bmw_fzv
SCHEIBE_ABSENKZEIT
wert_01
ohne_eks
wert_01
SCHWELLE_MERHK_KS
wert_01
SCHWELLE_MERHK_OL
wert_01
stufe_2
nicht_aktiv
nicht_aktiv
aktiv
nicht_aktiv
16_min
nicht_aktiv
wert_01
wert_01
wert_01
sofort
VERZOEGERUNG_SHD_KS
sofort
WARMUEBERWACHUNG_AL
aktiv
WARMUEBERWACHUNG_BL
aktiv
aktiv
aktiv
aktiv
WARMUEBERWACHUNG_FL
aktiv
aktiv
aktiv
aktiv
aktiv
nicht_aktiv
nicht_aktiv
wert_01
keine_vollendung
wert_01
XENON_TEST
aktiv
XENON_TIME
wert_01
XENON_TIMEOUT
wert_01
wert_01
wert_01
ZSW_AUS_BEI_KL_50
aktiv
KS_ABSCHALTUNG_AL
nicht_aktiv
KS_ABSCHALTUNG_BL
aktiv
nicht_aktiv
aktiv
aktiv
KS_ABSCHALTUNG_FL
nicht_aktiv
KS_ABSCHALTUNG_IB
aktiv
KS_ABSCHALTUNG_KRB
nicht_aktiv
KS_ABSCHALTUNG_KZL
nicht_aktiv
KS_ABSCHALTUNG_NSL
aktiv
KS_ABSCHALTUNG_NSW
nicht_aktiv
KS_ABSCHALTUNG_SL_H
nicht_aktiv
KS_ABSCHALTUNG_SL_I
nicht_aktiv
KS_ABSCHALTUNG_VA
aktiv
KS_ABSCHALTUNG_ZSW
nicht_aktiv
ALARM_MUW_SENSOR
aktiv
aktiv
aktiv
nicht_aktiv
aktiv
LWR_POS2
wert_03
LWR_POSR
wert_03
aktiv
MIT_NSL_RECHTS
nicht_aktiv
PWM_ANSTEUERUNG_IB2
wert_01
WARM_WITH_OL_BTS716
nicht_aktiv
aktiv
ZENTRAL_FH_SCHALTER
aktiv
wert_01
BLS_POLL_TIME
wert_02
aktiv
FLC_FAILSAFE
aktiv
FLC_OHNE_RLS
nicht_aktiv
MIT_FLC
aktiv
MIT_FLC_SCHALTER
aktiv
MIT_WWA
aktiv
wert_01
wert_01
wert_02
ANLIEFERKODIERUNG
nicht_aktiv
KALTUEB_AUS_BEI_SCG
aktiv
wert_01
wert_02
wert_01
nicht_aktiv
TILT_SIRENE
aktiv
TM_ENTR_HECKKLAPPE
aktiv
WWA_LED_KL15_DAUER
wert_01
WWA_LED_MOT_DAUER
wert_01
WWA_LED_TAKT_AUS
wert_01
WWA_LED_TAKT_EIN
wert_01
WWA_LED_TRIG_DAUER
nicht_aktiv
WWA_LED_WASCH_DAUER
wert_01
TM_FOLLOW_ME_HOME
nicht_aktiv
TM_POSLIGHT
nicht_aktiv
AUTOM_ER_KEY_OFF
nicht_aktiv
EXT_BEREICH_KURZHUB
wert_01
aktiv
MAXWERT_FH_POS_HB
wert_01
MAXWERT_FH_POS_LB
wert_01
gnanneb86
Jan 16, 2019 01:52 PM
R50/53 Electronics/Ignition Issue
John Trujillo
Nov 22, 2016 01:13 PM
tgauth
Jul 29, 2009 05:29 AM
