R50/53 Clutch Switch
Old Jul 22, 2025 | 02:37 PM
Luis1008's Avatar
Luis1008
Clutch Switch
Issue with starting the car. Starter was already changed, eliminating other culprits.
Could someone please tell me where this part is located on my 2002 MCS?
Old Jul 22, 2025 | 04:51 PM
cooper48's Avatar
cooper48
Check #4 above first. It's located on the clutch master cylinder attached to the clutch pedal inside the car. It's an ignition lockout switch and must be attached to the clutch master cylinder in order for the car to start (they can become disconnected). It's also possible that this switch is defective and causing your no-start issue. The switch is only ~$23.
Here's a link: https://www.partsgeek.com/catalog/20...ck_switch.html
Old Jul 25, 2025 | 11:26 AM
+1 right here most of the time: https://www.ecstuning.com/Search/Sit...h/35426876898/
https://www.northamericanmotoring.co...-cylinder.html
https://www.northamericanmotoring.co...er-switch.html
Also check that ignition:
https://www.northamericanmotoring.co...-r53-help.html
Old Jul 26, 2025 | 05:37 PM
Luis1008's Avatar
Luis1008
Thanks! I ordered the part from ECS on Friday, and it should arrive on Monday. Finger crossed.
Old Jul 28, 2025 | 07:45 AM
Thanks, glad to help.
Old Jul 31, 2025 | 09:56 AM
Luis1008's Avatar
Luis1008
Ok, switch was replaced first try nothing, second try I could hear the car trying to starter trying to turnover and with in a sec or two it turned over. Car was moved turned off and has not turned back on since. Any Ideas where to go from here battery is not old and it did turn over today like i stated, but now I dont even hear the starter trying to engage
Old Jul 31, 2025 | 11:37 AM
ssoliman's Avatar
ssoliman
sounds like dead battery or loose ground but thats just a guess
something to try. check all grounds. start at battery then ground at right side of engine bay
Old Jul 31, 2025 | 12:20 PM
cooper48's Avatar
cooper48
Have you tried jumping the battery with another car? If it jumps and starts then your battery is suspect. Your battery, though not old, could have a dead cell. First task is to have it tested. MINIs are notorious for having problems with a weak battery. Testing is free at AutoZone, O'Reilly's, etc.
Old Jul 31, 2025 | 12:43 PM
Luis1008's Avatar
Luis1008
Thank you for the advise, I have a tester checked it a couple weeks ago when issue presented itself and it was in the green, will check again. Just rolled it down the hill popped the clutch and still did not want to turn over, that is a 1st for me.
Old Jul 31, 2025 | 02:24 PM
cooper48's Avatar
cooper48
Were you in first, second or third gear?
Old Aug 2, 2025 | 01:23 PM
Luis1008's Avatar
Luis1008
Update: The car started consistently once the battery ground wire was cleaned and lubed. Thank you all for helping me out,
NC TRACKRAT
Jun 12, 2024 06:38 PM
czastrow
Jun 28, 2021 02:26 PM
RatBlast
Jul 31, 2008 06:12 PM
DVLMINI
Jun 18, 2007 06:44 AM
Petrich
Feb 17, 2003 08:05 AM
