R52 06 R52 Manual, do I have a LSD installed?
Old Jul 16, 2025 | 04:19 AM
TheBelcherMan's Avatar
TheBelcherMan
Owned the car forever (2nd owner, no sticker) and always figured it didn't have a LSD. Really had nothing to go on but for the fact that it's near impossible not to spin the tires on a aggressive launch.
Yesterday I was trolling the forums and found a site that stated every R52 with a manual gearbox shipped with a LSD?
Here is the thread I was reading.
History of the Australian R50
My R52 was manufactured for the US market, did they also all ship with LSD's installed?
Without pulling the trani and cracking her open, is there a way to tell?
Fired up the laptop and grabbed the DSC's coding data.
There are several functions that make me think there is no LSD installed. Again, based on nothing but a hunch.
1. Differential locking control: Not Enabled
2. Differential Traction control: Not Enabled
3. Logic Limited-Slip Differential: Not Enabled.
I've attached the trace files for your viewing pleasure.
Thoughts?
File Type: zip
Old Jul 16, 2025 | 07:53 AM
Hello,
PM me the vin and i can check.
Mike
Old Jul 19, 2025 | 03:30 PM
Mineeee's Avatar
Mineeee
Jack up both sides and see what happens when you spin a wheel. Definitely not true that all the manuals had the LSD. Most didnt
Old Jul 19, 2025 | 04:36 PM
TheBelcherMan
@Mineeee
I haven't had a chance to get the front end up and test, it's hot as ***** here in Tampa. Just brutal.
It did have to give that post a 2nd read to make sure I had read it correctly. Maybe it was true in the AU market, cause I'd bet the farm mines has nothing but a bone stock open diff in there.
Thanks for taking the time to share your knowledge! Cheers.
Old Jul 20, 2025 | 02:25 AM
BoostedBlueToyotas's Avatar
BoostedBlueToyotas
US R52 did not get limited slip differential as standard (unless it was factory equipped with the JCW package). There is a white
label on drivers side of the transmission (down by the axle). If it has a BKL code it has factory LSD. If BKE or other it is
a open diff.
Old Jul 20, 2025 | 08:06 AM
TheBelcherMan
@BoostedBlueToyotas
Just amazing, the breadth of knowledge you guys posses.
Thanks all.
Old Jul 20, 2025 | 11:25 AM
cooper48's Avatar
cooper48
The easy way to check LSD is to jack up the vehicle and turn one of the front wheels by hand. If the opposite front tire turns the same direction you have an LSD.
Old Jul 20, 2025 | 01:42 PM
TheBelcherMan
@cooper48
I had read this was a way to test. Now hearing from you guys, I know it's valid.
Much appreciated.
RIPPER
Nov 21, 2023 10:34 AM
LiquidElephant
Jul 5, 2017 03:29 PM
Whine not Walnuts
Nov 16, 2016 05:01 PM
metalmonkey47
Jul 25, 2015 09:54 PM
o-ron
Apr 9, 2006 07:24 PM
