R50/53 Head cover tube question
Old May 24, 2025 | 06:42 PM
Mforce's Avatar
Mforce
Hello,
Just a quick question, if you are facing the engine from front of the car what is this tube for? another PCV valve? ( on right )?
Please see below. Thnx in advance -- I have a R53 2004
Old May 25, 2025 | 03:49 AM
deepgrey's Avatar
deepgrey
It’s a breather.
Old May 25, 2025 | 08:36 AM
Whisky B's Avatar
Whisky B
Yes, it's another valve cover vent port, the line should run down into the main air intake tube. You can cap the line with a breather filter and close off the inlet on the main air intake to avoid oily pcv residue building up in your intercooler w/o throwing a code.
Old May 25, 2025 | 05:59 PM
Mforce's Avatar
Mforce
Deepgrey and WhiskyB,
wait if this is the breather why put in a PCV valve? and when you say breather is it air coming to engine? or coming out?
Old May 26, 2025 | 06:26 AM
deepgrey's Avatar
deepgrey
When the PCV valve is open, it’s a fresh air source for the crankcase. When the PCV valve is closed (high manifold vacuum), it’s effectively a vent outward.
The system goes back to at least the sixties; my van has one. The breather is the oil cap, and there’s a line from the PCV valve to the carb.
Old May 26, 2025 | 07:41 AM
ssoliman's Avatar
ssoliman
interesting. what does the "breather filter" look like
Old May 26, 2025 | 10:57 AM
deepgrey's Avatar
deepgrey
I remember someone running a cylindrical filter like you’d put on a small block, though it may have been smaller than one of those.
Old May 26, 2025 | 02:42 PM
Here2Go's Avatar
Here2Go
NAM Community Team
Yep. I had added a small cone type filter on that breather outlet and posted a picture of it here on NAM, after installing my Catch can.
I was kindly informed by a credible contributor here, that the Supercharged Mini engine is a and intended as a 'closed system' and furthermore a filter on that outlet only defeats its engineering and is not recommended.
I removed the filter and ran the hose back to original/stock.
scubus
Aug 30, 2021 07:58 AM
jjcsnlynn
Jan 12, 2019 08:28 AM
Scooter24
Jun 19, 2018 02:08 PM
Porthos
Feb 28, 2012 07:23 AM
R56 Wi MINI
Feb 24, 2010 07:02 PM
