R56 Windshield Cowl Seal Replacement help
Old May 7, 2025 | 10:50 AM
z168's Avatar
z168
So after 10 years, its time to yet again replace the windshield cowl.
Back in 2018 I only replaced the two large trim pieces as below
This time for 2025, I need to replace both the trim pieces above and the long rubber weatherstrip on the base of the windshield
This is the problem - this rubber strip wont hold on to the glass and keeps falling off. Its not an easy push in.
Any actual experience on getting this installed appreciated.
Old May 7, 2025 | 11:41 AM
z168's Avatar
z168
ok looks like I solved it. I cut and removed the entire lower rubber appendage that would sit under the glass and firewall. May have been a residual from manufacturing. I can see how it would be easier to install this with the windshield off the vehicle.
Anyway, problem solved
Old May 7, 2025 | 11:44 AM
https://www.northamericanmotoring.co...need-help.html
Sometimes the sealing material from the windshield being replaced (betalink) or windseal rubber needs cut back a little on the underside of the glass.
Old May 20, 2025 | 03:09 AM
Seaswood's Avatar
Seaswood
I had windscreen removed to have that done!
Old May 20, 2025 | 06:32 AM
Yep safelite and some other repair places are known to use too much window seal and it comes out the bottom of the seam between the window and body. I had mine done and their screwed up multiple times on my R56 and R58.
I had them break the A pillars cover and then they did not tell me. I found out when i looked at the job afterwards and they use wind seal to adhere the a pillars back on. They cover the cost of the new ones when i reported it.
Old May 22, 2025 | 02:25 PM
z168's Avatar
z168
Trimming the bottom rubber flap for the entire length of the seal did the trick.
Old May 22, 2025 | 03:58 PM
mkov608's Avatar
mkov608
We also had to have the wind shield removed and reinstalled due to too much sealant.
Ocramida
F54 :: Clubman Talk (2015+)
Apr 23, 2022 06:34 PM
mini_aaron
Jun 25, 2015 06:24 AM
maldav
Jun 28, 2009 01:32 PM
sammyk
Chicago MINI Motoring Club
May 5, 2008 10:26 AM
dominicminicoopers
Jun 2, 2003 08:13 AM
