P0597: Thermostat Heater Control Circuit/Open
Old Mar 18, 2025 | 06:27 AM
JAMADOR's Avatar
JAMADOR
Had this pop up yesterday, read/cleared the MIL with my BlueDriver.
Popped back up today on my drive in to work.
Simple as a thermostat replace? Or is there more to it?
Old Mar 18, 2025 | 03:32 PM
JAMADOR's Avatar
JAMADOR
Ran the BlueDriver on the drive home
Ambient temps: high 70s to low 80s
IATs: 96-111
ECTs: 196-207
Briefly looked under the hood, nothing looks remotely accessible & a quick browse of ECS, doesnt look like a typical thermostat replacement. Have to replace the entire housing?
Old Mar 19, 2025 | 06:54 AM
Hello,
Unplug the connection and replug them in on the electrical. Some of the connection and pins on those units. If that still does not work then its a bad thermostat.
https://www.northamericanmotoring.co...ode-p0597.html
Old Mar 19, 2025 | 07:18 AM
JAMADOR's Avatar
JAMADOR
Thanks, I'll try that first before spending any $ on replacement parts.
Anyone have a photo/diagram of what I'm looking at? Didn't see anything obvious in a cursory look under the hood yesterday.
Old Mar 20, 2025 | 06:57 AM
JAMADOR's Avatar
JAMADOR
I'm going to try the mentioned unplug & plug it back in, before spending any $ on it.
Just need to figure out what I'm looking at under the hood.
Old Mar 22, 2025 | 11:15 AM
JAMADOR's Avatar
JAMADOR
Well, pulled both connectors, no corrosion & both looked good.
Plugged back in, cleared codes. CEL came back.
Guess I'm planning on a tstat replacement
Old Mar 24, 2025 | 07:41 AM
Yep, check those pins also as they like to bend. If their are straight and even then its a new thermostat housing.
Old Mar 24, 2025 | 07:45 AM
JAMADOR's Avatar
JAMADOR
All looked good & clean best I could tell in the limited space in there.
I saw that the tstat options on @ECSTuning all say an adapter/replacement wire/connector is needed. Does this replace one of the wires, or jump from the existing to the replacement tstat?
Old Mar 24, 2025 | 07:49 AM
For select models on their first replacement you will need that adapter. If its been replaced before you will see that adapter already installed on your car.
For vehicles with production from 6/2010 to 3/2012 Base/JCW models will require ES2558172 if this is the first time being replaced. Check your production date: https://www.realoem.com/bmw/enUS/select put your last 7 digit here and this will tell you.
https://www.ecstuning.com/Mini-2010-...ngine/Cooling/
Mike
Old Mar 24, 2025 | 07:52 AM
JAMADOR's Avatar
JAMADOR
12/2009 based on that realoem lookup.
So, does that mean I just need the tstat & new coolant?
Old Mar 25, 2025 | 12:42 PM
JAMADOR's Avatar
JAMADOR
@ECSTuning
Can you confirm the adapter harness isn't needed for a late '09 build?
Also, for the group, what's the coolant type for these, and capacity?
Old Mar 25, 2025 | 12:46 PM
Nope not needed based of MINI etk.
MINI coolant will be G48 coolant (same as oem MINI) this is the blue coolant. Mix 50/50 with distilled water if concentrate. I used one MINI 1 Gallon bottle and mixed it 50/50. 2 gallons total. That was enough to do the job.
https://www.northamericanmotoring.co...formation.html
Old Mar 25, 2025 | 12:48 PM
JAMADOR's Avatar
JAMADOR
Thanks. Order will probably be inbound shortly.
Then to find the time to R&R
Old Mar 26, 2025 | 07:37 AM
JAMADOR's Avatar
JAMADOR
Tstat ordered, hopefully no surprises when I do the R&R
Old Mar 30, 2025 | 03:27 PM
JAMADOR's Avatar
JAMADOR
2 hours & some colorful commentary later, it's done with no leaks & no CEL.
Overall not a bad job, the hose clamps were a small pain, but the clip for the water pipe flange took the most time. Easy to remove, massive pain to reinstall.
Everything is in the way of getting the clip in place. Finally got it started with a pair of needlenose pliers & slipped it on by hand afterwards
Old Mar 30, 2025 | 10:34 PM
bluonyx's Avatar
bluonyx
Thanks for all the info. My thermostat just went and threw up this code. Now I know what I'm getting myself into.
Old Mar 31, 2025 | 06:36 AM
JAMADOR's Avatar
JAMADOR
That clip was the only real pain of the process.
I'd guess I tried at it for nearly 1/2 hour before getting it on.
No issues on the run to work this morning, got a little hot but kicking the A/C on brought the ECT down. Got up to about 230 in stop/go heavy traffic when I kicked the AC on to get the fan pulling air though the rad.
What's the normal operating hot range on these?
Old Mar 31, 2025 | 08:00 PM
bluonyx's Avatar
bluonyx
Before tune 220-230, after tune 190-200
Old Apr 1, 2025 | 06:08 AM
JAMADOR's Avatar
JAMADOR
Thanks, I saw it creep over 230 & got a little worried.
The Zerex G48 has a max of 265, but don't think I'd ever let it get that hot.
Old Apr 1, 2025 | 06:47 AM
Yes these Gen 2 MINIs cars run hot. My JCW in the summer sit at 219. When i put it in sport mode or run the A/C it drops.
Old Apr 1, 2025 | 06:48 AM
JAMADOR's Avatar
JAMADOR
Thanks to you both.
Glad I have the BlueDriver, not having a temp gauge is definitely a deficiency on these.
hooverr77
Aug 23, 2020 09:15 AM
nwflyingdutchman
R60/R61 Stock Problems/Issues
Dec 7, 2017 12:52 AM
scarabbrian
Nov 26, 2016 07:35 AM
Old School
Nov 24, 2016 07:58 AM
scott48
Sep 10, 2010 11:16 PM
