6mt Shift linkage "ball" loose
Old Mar 10, 2025 | 06:17 PM
wkndracr's Avatar
wkndracr
So I had a slightly stiff shifter and decided to take a look at the linkage under the air box. Sprayed some lube on the moving parts which loosened up the shifter a bit, but noticed one the ball that the top shift cable snaps on to is loose. There doesn't seem to be any way to tighten it, looks like the back side is flared out, kind of like a rivet. Is there a replacement for these or way to fix it without having to buy a whole "shift unit" as it's called? Seems like if left alone it will fail at some point, leaving me not being able to shift.
Old Mar 10, 2025 | 06:28 PM
wkndracr's Avatar
wkndracr
After searching a bit more, I think I may have found my answer. Seems one way to fix is to just weld it. Is that the consensus? Pic of the actual part that's loose.
Old Mar 11, 2025 | 12:18 PM
mrbean's Avatar
mrbean
If you can't weld it you might try one of these.
https://www.mcmaster.com/products/ba...gas-springs-7/
Old Mar 13, 2025 | 01:07 PM
+1 Yep or you have to replace the whole pivot piece on top or weld or get that piece and weld on.
https://www.northamericanmotoring.co...se-advise.html
https://www.ecstuning.com/Search/Sit...h/23117572703/
Old Mar 14, 2025 | 12:50 PM
wkndracr's Avatar
wkndracr
Ended up borrowing a welder from the muffler shop next to the shop I work at. It ain't pretty, but it works!
BigBri
Nov 8, 2017 08:00 AM
Rrotz
Jun 4, 2015 05:09 AM
bluefox280
Sep 21, 2011 12:36 AM
scottab36
Sep 21, 2009 04:45 AM
Adnuo
Dec 20, 2006 01:47 PM
