R56 Oil Filter Housing non return valve O ring
Old Jan 29, 2025 | 10:49 PM
Lipofskyphoto's Avatar
Lipofskyphoto
I just did an oil change on a 2009 (It's actually an R55) and found a split o ring smaller than a dime in the filter housing.
I found a Mini Tech bulletin (attached) that said the o ring would have come from the non return valve and the only fix is to replace the oil filter housing.
I have an R56 donor car. Can I remove the whole non return valve assembly from the R56 and transplant? If so, is there a trick to removing it?
Alternatively, can I just replace the O Ring? If so, any advice on how. Do you happen to know the size of the O ring?
Thanks!!
File Type: pdf
Old Jan 30, 2025 | 08:32 AM
Dont know the size of that o-ring, we have the full housings in the aftermarket. If you have an oil leak at the block/filter location, i would just to the whole thing.
If not you can take down the o ring and match it up with another one local, get a hair smaller maybe so it holds.
Old Jan 30, 2025 | 09:11 AM
Lipofskyphoto
Thanks ECS
There's no leak.
Any advice on how to replace the o-ring?
Old Jan 30, 2025 | 01:26 PM
Seaswood's Avatar
Seaswood
there is a large oring some similar oil filter covers have a small oring at end.
https://www.realoem.com/bmw/enUS/sho...diagId=11_3930
Old Jan 30, 2025 | 05:10 PM
Lipofskyphoto
Does anyone have an oil filter housing out of the car such that they could check how to remove the anti return valve and/or the O-ring?
It would be a great help!
Old Jan 31, 2025 | 06:41 AM
Hello,
Let me pull one apart today.
Mike
Old Jan 31, 2025 | 06:45 AM
Lipofskyphoto
Mike,THANKS! That would be a lifesaver!
I'd love to know if it's possible to slip a new O-Ring on or remove the assembly and transplant it from my donor car.
Can I trouble you to send a photo of the assembly when it's out? Posted here or to my email: Lipofskyphoto@gmail.com
Old Jan 31, 2025 | 08:17 AM
Ok, look at both the N14 and N18 oil filter housing, Its pressed in from back. Unless you unpress the flow back section, i dont see it coming out without breaking, hence why MINI says to fully replace.
Sorry i could not help.
Old Jan 31, 2025 | 08:24 AM
Lipofskyphoto
Thanks for taking the trouble to check! That's a great help knowing that I can't remove the whole assembly.
I talked to a Mini service dealer and he says that I should be able to slip a new O-Ring on.
Old Jan 31, 2025 | 08:25 AM
Ok, i dont know if you can get in their to do it, all looks press fitted for the main section.
https://www.ecstuning.com/b-bremmen-...428643762~brp/
Let me know what happens.
BTW this is the R55 Clubman NON S filter housing 2007-2010
Old Jan 31, 2025 | 08:29 AM
Lipofskyphoto
Thanks. The O-ring is located in the inside part of the housing where the filter sits.
Do you have a photo of the valve seen from the inside of the housing where the filter sits?
Old Jan 31, 2025 | 08:37 AM
Hello,
Not on that part but i know what it is. Just looked at it and i dont know if you can get in their either.
2nd Gen
Preview image for a collapsed post.
Old Jan 31, 2025 | 08:42 AM
Lipofskyphoto
Thanks so much. I really appreciate the time you put into this!
The mini service guy seem to think that I can do it, but also said that the loss of the o-ring shouldn't be a critical problem for the car.
He's going to get back to me with the dimensions of the Ring.
Your explanation of the press fit from behind explains why I can't get the assembly separately or see a full picture of the assembly.
Old Jan 31, 2025 | 09:11 AM
Gubi's Avatar
Gubi
What's the consequence if that o-ring slips out? That's the non-return valve, apparently. Is it the return from the block or the return to the sump?
I'm guessing your filter would drain when sitting, causing low oil pressure at initial startup, right?
Old Jan 31, 2025 | 09:14 AM
Lipofskyphoto
I think that you're exactly right.
You would be pumping a little bit of Air instead of oil through the system at startup.
I think over time, this could produce a little extra engine wear.
Changing that filter housing is a bit of a monster and you usually have to put the car into service mode.
I'm going to hope that I can get that o-ring on.
Old Jan 31, 2025 | 09:24 AM
Yep low pressure warning, people have companied about that before and it was a broken return valve system.
Old Jan 31, 2025 | 09:28 AM
Lipofskyphoto
Yes, the service guy said that was a possibility, but not necessarily going to certainly happen
Old Feb 10, 2025 | 06:45 PM
Lipofskyphoto
Problem solved!
I used a Danco #48 O-ring (cost 99 cents)
I carefully worked the O-ring over the spring of the non-return valve until it sat under the spring.
I then carefully seated the O-ring into the round groove at the bottom of the spring using a small screwdriver.
I ran the car and checked the filter housing. The housing retained oil as it should as opposed to being empty of oil before the repair.
Old Feb 10, 2025 | 06:52 PM
Gubi's Avatar
Gubi
Nice work!
coopy56
Feb 19, 2025 07:51 AM
Rusty12
Jan 31, 2025 11:34 AM
MiniPOLACK
Mar 15, 2014 04:21 PM
BoostinZX
Jan 17, 2011 05:08 AM
frankhuzzah
Nov 18, 2007 06:59 PM
