R56 Mini leaks fixed for now
Old Jan 28, 2025 | 06:48 AM
Seaswood's Avatar
Seaswood
R56 2009 mini S
i finally had to have a garage pull wheel bearing after several cans of blaster no extra room motorcycles a rover in same one car garage.
repairs done to seal engine appear to not be leaking on drive home, oil filter housing & cooler, turbo oil lines, O2 sensors, front main seal, oil pan gasket, replaced coolant overflow tank.
fitting for windscreen washer is I thought was a plastic clip?
And I believe shock bolt on top had covers I cannot find if you know part numbers?
Old Jan 28, 2025 | 08:16 AM
Shock mount covers: https://www.northamericanmotoring.co...ml#post4689869
OEM part: 31311139453
That one near the washer bottle is this one.
https://www.ecstuning.com/Search/Sit...h/51471911992/
Old Jan 28, 2025 | 09:32 AM
Seaswood's Avatar
Seaswood
Thnx
shock mount covers HD part # ?
that requires shock removal?
Old Jan 28, 2025 | 09:48 AM
Hello,
Those covers fit all the Genuine and aftermarket (follow Genuine MINI design), plus our HD mounts.
Snap the caps in the center in your done.
ECS HD mounts match the oem design, just higher durometer rubber.
jjcsnlynn
May 9, 2023 03:59 PM
Andryiakathlene
Aug 12, 2018 10:28 AM
Gregoogle
R55 :: Clubman Talk (2008+)
78
Mar 4, 2016 09:09 AM
kellmeister
Dec 18, 2015 02:02 PM
coffan
Mar 13, 2014 03:38 PM
