R50/53 Help with CV Axle Install
Old Jan 1, 2025 | 06:19 PM
Kuni1222's Avatar
Kuni1222
Hi all,
I've just received new CV axles for my R53 and was glad that I got the right side axle that has the bearing bracket already installed. I've watched Mod Mini's YouTube videos (super helpful!) and was worried I'd have to move the bracket.
I got everything into place and the bolt holes for the bracket are just slightly off toward the passenger side. It's as though the axle end needs to seat farther into the transmission or the bracket needs moved ~1 mm to the left. Very frustrating. I've double checked everything from the axle manufacturer and it shows that I have the correct model for my exact spec vehicle (2006 R53 S, Manual transmission).
Any and all tips or advice are welcome! I'm considering getting an axle from a different manufacturer and trying it...
Pax side axle entering transmission. It
Pax side axle entering transmission. It "clunks" like it's fully seated, but does it look OK?
Bracket bolt holes not quite lining up.
Old Jan 13, 2025 | 07:25 AM
junits15's Avatar
junits15
Is the carrier bearing fully seated on the axle? Had nearly the exact same issue with an axle from NAPA, the carrier bearing wasn't fully seated on the shoulder before the inner CV joint. That bracket doesn't look like its fully seated either.
Old Jan 13, 2025 | 07:53 AM
LukasH's Avatar
LukasH
On my R53 the brackets don't line up visually but the bolt holes do. I'm pretty sure I still have the stock axels on my car.
Also, sometimes an axel doesn't go into the gearbox fully. What I then do is using the brake disc to rotate it slightly and then it pops in.
Hope this helps.
Old Jan 13, 2025 | 01:20 PM
ssoliman's Avatar
ssoliman
looks like it just needs to go in a bit more on the gearbox side. what brand are the new shafts?
Old Jan 13, 2025 | 04:01 PM
cooper48's Avatar
cooper48
Did your replacement axle come with the bearing housing already installed over the bearing, or did you remove the housing from the original axle and install it on the new one?
Old Jan 20, 2025 | 06:25 PM
Scoobaru2010's Avatar
Scoobaru2010
If you have a spare axle nut thread it on a few threads then tap it with a hammer. Or get under with a pry by and pry against the carrier bracket, done both with stubborn cv's. The r53 passenger side can be a bugger!
best of luck
Old Jan 31, 2025 | 06:01 AM
GLTHR53's Avatar
GLTHR53
I had this issue and the only way I could fix it was to remove the axle and move the carrier bearing outward on the shaft to allow the splines to go further into the transmission. I had leaking trans fluid before I did this and now it's fixed. No other way to do it.
Old Feb 1, 2025 | 08:31 AM
junits15's Avatar
junits15
this is the right answer, the carrier bearing needs to move
Old Feb 11, 2025 | 05:02 AM
Boostmaster's Avatar
Boostmaster
Just my .02 here. After fighting with mine I discovered than one cannot simply push these in and call it good. You need to give them a good whack to seat them. They may "feel" like they are seated but trust me they need some persuasion.
https://www.northamericanmotoring.co...-ideas-11.html Take a look at post #267 for some pics that might help
Old Feb 12, 2025 | 08:03 AM
Krunch2020's Avatar
Krunch2020
Mod Mini
The Mod Mini video shows him using the weight of the brake and rotor to whack it into position. It will not just slide into position.
Kurt
gimmea250swb
Sep 29, 2024 05:36 PM
Mccannro
Nov 10, 2023 02:58 PM
jetsr6
Jun 2, 2021 08:19 PM
bimmadave
Nov 12, 2016 02:46 PM
myla2003
Dec 11, 2009 08:14 AM
