R56 Bump steer after some work
Old Oct 24, 2024 | 05:55 AM
gimmea250swb's Avatar
gimmea250swb
I installed new control arms and bushing and driver CV joint. Now when driving the car it periodically jumps left or right randomly. Not during acceleration/deceleration. The steering wheel is turned left maybe 5 degrees to go straight and it seems to have a slight touch of slop that I don’t remember being there before. I haven’t gotten it back on the lift to check bolts. My guess is something is loose. I’m on a trip so thought I’d post this to see if anyone had other thoughts. Both steering knuckles were detached and I dropped the subframe for the repair.
Old Oct 24, 2024 | 08:48 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Did you get an alignment performed after the work? Dropping the subframe, replacing control arms and bushings, and replacing a driveshaft... your alignment is surely off.
Old Oct 24, 2024 | 10:37 AM
gimmea250swb
Thanks. I didn’t. When I get back, I’ll jack it up and check if the wheels wobble. I suspect something’s loose. Then off for alignment
Old Oct 28, 2024 | 05:19 PM
gimmea250swb
Closing this out. The last guy who bolted it all together didn't fully tighten the nut on the tie rod to the steering knuckle. What an idiot!! When I (ummm, he) tightened it, there must've been some back pressure to keep it from tightening all the way.
I jacked the car up and was easily able to wobble the wheel. Quick fix and back on the road...
CarFreak427
Suspension
15
Jan 4, 2024 03:24 AM
cewyattjr
14
Feb 10, 2018 05:28 AM
DandoOneWord
Jul 2, 2016 03:41 AM
2004mc40
Dec 10, 2015 04:53 AM
1QKMNIS
Nov 21, 2006 12:34 PM
