2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 Differenctial oil change
Old Oct 9, 2024 | 04:20 PM
heticor's Avatar
heticor
I am looking for the procedure how to the replace the differential oil, transfer case, and transmission.
type oil, and quantity.
Old Oct 9, 2024 | 07:08 PM
Mini-Titan's Avatar
Mini-Titan
The differential only has a fill plug...no drain. So, it's a matter of getting a new fill plug, sticking a tube into the differential and aspirating whatever volume you can get, and refilling with the SAME VOLUME you removed. Unlike MOST differentials, this is NOT a "fill until it runs out" process. It will be over-filled if you fill until it runs out.. The differential fluid is a 70w80 concoction that costs about 80.00 for half a liter. When I did the two F60's I've had, I believe I was able to get right at 350 mL aspirated out of each one. So, 350 went back in. No fluid ran out of the fill hole of either one.
8-speed auto is what both of my F60's have. I did a drain-and-refill. I did NOT have the correct tool to bring the trans temp up to the specified temp where the standpipe defines the correct level when the car is running (and I believe in park after shifting through the gears). Another hard thing about doing it this way is the car is supposed to be running...but you have to take the airbox out to get to the fill plug. I guess you over-fill it so you don't have to go back in and take everything apart again if you didn't have quite enough? Expensive fluid to purposefully put too much in. Instead, I did a similar drain, measure, and refill with exactly the same volume of fluid...and both the drain and the fill fluid were exactly the same temperature. I did this by draining the fluid after not driving for over-night, and the new fluid was stored right by the car. Doing it this way, I can drain about 2.75 quarts. I put that much back in...go drive a while, and repeat the overnight parking and do it again. I probably only replace about 1/2 of the total volume. But, these are "lifetime" fluids, so what I do is better than nothing.
That leaves us with two more fluids. Transfer case and "Hang-on-clutch" (assuming you have All4 system). I've never done either because the instructions I find say the viscosity of the new fluids must be programmed into the computer after their respective changes. The transfer case fluid is going to be an "aspirate and refill" similar to the differential. I'm not sure about the Hang-on-clutch (this is located just in front of the rear differential). If I end up keeping the car for what I'd guess would be 75,000-100,000 miles, I'll probably have both of these done at a shop at about 50,000 miles. Again, both are "lifetime fluids", although I certainly don't trust the transfer case fluid to last in very good condition much past 100,000 miles.
The drained Rear Diff fluid was very nice in appearance, as was the transmission fluid....both looked very much like the new replacement fluid. Both cars were done with about 30,000 miles on them So, at 30,000 miles I'd say you are WELL ahead of taking good care of those fluids. Perhaps 50,000 miles would be more than sufficient.
Hope this helped!
Old Oct 10, 2024 | 10:24 AM
Yep more info here on it:
https://www.northamericanmotoring.co...placement.html
Old Oct 10, 2024 | 11:22 AM
Mini-Titan's Avatar
Mini-Titan
Also note that my 2019 JCW Countryman compared to my 2020 JCW Countryman, there was a change in Transmission fluid from ATF 6 to ATF 7. I know the 2020 has a much firmer shift feel...so there is perhaps a different friction coefficient used in the two versions of ATF. Make sure you get the right one for your vehicle.
Old Oct 21, 2024 | 12:54 PM
heticor's Avatar
heticor
Capacities
Thank you for the good information.
any body know the amount a type of fluids for :
Automatic Transmission, I believe this AT is 7 liters but I not sure.
Transfer case
Rear differential
Front differential
Old Oct 23, 2024 | 02:19 AM
Mini-Titan's Avatar
Mini-Titan
If you are doing a drain/refill, I only get about 3.5 quarts out. Transfer case, I don't know, but it's an "aspirate and refill" job, which is definitely less than a quart. Rear diff is an aspirate and refill...which is about 350 ml (the 70w80 fluid comes in a 500 ml bottle, and is expensive!). Don't know anything about the front differential. But, these cars also have a Hold-on-Clutch fluid just in front of the rear differential.
I've read that there may be coding involved when changing either the Transfer Case or HOC fluids...apparently the computer/sensors are very picky about current viscosity...
Old Jun 5, 2025 | 07:10 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Hope this helped!
Which "tool" did you use to suck out the fluids?
Old Jun 5, 2025 | 08:01 AM
Mini-Titan's Avatar
Mini-Titan
I have what is called a "weighted sump", which is a flexible plastic tube with metal weights at the end. (It's used in heart surgery and some other types of surgeries.) I've seen metal tubes bent at an angle, with a plastic hose attached to it. Something that can curve over the fill hole entry point and reach down toward the low-point works well.
Old Jun 5, 2025 | 08:53 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Gotcha, thanks. I'm planning out my fluid change....
Old Jun 5, 2025 | 06:50 PM
Mini-Titan's Avatar
Mini-Titan
If you do the transfer case, let me know if you had to take some underside bracing/bracket off. I haven't yet found a 2020 YouTube on whether that's in the way on my model year. Thanks!
Old Jun 6, 2025 | 03:39 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Old Aug 1, 2025 | 08:56 AM
Steve500's Avatar
Steve500
Hope this helped!
There's a decent video on youtube of the BMW X1 showing that the rear haldex differential can be separated to drain all fluid, refill, and clean the hydraulic pump intake filter screen. Quite a teardown just for maintenance but at the same time, it's not a lot of teardown, the differential is a pretty simple unit. VW takes a huge win for making this far easier on their vehicles with the same style differentials.
Old Aug 1, 2025 | 03:09 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
To change the fluid in the transfer case, I only had to remove the splash shield. No bracing was in the way for me.
Old Dec 1, 2025 | 04:00 AM
GeoCS's Avatar
GeoCS
i done mine , it was quite easy , auto transmission and only rear differential , need to do the hung on clutch and the front differential , if im not wrong
just beware for the auto transmission , get the temps through obd and drain a bit from underneath .
Old Dec 1, 2025 | 06:43 AM
Steve500's Avatar
Steve500
you were able to clean the pickup filter on the pump of the rear differential?
Old Dec 1, 2025 | 06:54 AM
GeoCS's Avatar
GeoCS
no nothing ! i didn't touch that , difficult access , i used to done that on my old golf R ,it was easy to remove it pump and screen filter .
i dont think is so mandatory to clean this filter , the oil replacement is the big deal on this kind of maintenance ,
but to be fair if i had better access , i would do even the filter , i remember at the old vw haldex some of them they were somehow clogged , it was like screen filter full of ***** ! not always ..
Yoshimura 1
Mar 11, 2024 06:40 AM
Buckey
F54 :: Clubman Talk (2015+)
Apr 18, 2018 08:32 PM
S1monLM
Aug 9, 2011 06:46 AM
Ex-Pat Brit
Dec 15, 2007 06:54 AM
S Curvz
Off-Topic :: Autos
Nov 8, 2006 06:52 AM
