R57 DSC issues
Old Sep 22, 2024 | 06:10 AM
amatorMechanic's Avatar
amatorMechanic
DSC issues
Hi there,
CAR : Mini R57 Cabro 2009, 1.6L
Problem: Once DTC is cleared, the car is switched off. Once the ignition is back on, "Longitudinal Accelerration, Traversal Acceleration and Yaw-Angle Speed" sensors working and + - numbers shows up. However, after 20/30 seconds, Traversal Acceleration and Yaw-Angle Speed sets to 0 and only Longitudinal Accelerration changes value.
ps1. when clearinf DTC, I feel a click unsre the sterring wheel
ps2. on straight ahead driving, if i take hans off the steering wheel, the car steers to the left.
Question: whats oing on @ how can I fix it.
Any help will be appreciated.
Thanks.
Old Sep 22, 2024 | 07:16 AM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
...on straight ahead driving, if i take hans off the steering wheel, the car steers to the left.
Your mini most likely needs a front end alignment.
Old Sep 23, 2024 | 04:33 AM
amatorMechanic
Thanks "Maybe-maybe not" for your suggestion.
Took the car to garage this morning and alignment is done. However, problem is stil there.
Regards,
Old Sep 23, 2024 | 04:58 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
What are the actual code values that are stored? The actual codes are more helpful than the descriptive text that is mentioned. Any recent work done to the steering system? Has the steering column been disconnected from the rack for any work?
Based on what little information was provided, my gut says the steering angle position sensor is not aligned with the steering rack position sensor and needs to either be reset or realigned, or both.
Old Sep 23, 2024 | 06:20 AM
Maybe, maybe not
Community Builder
Regards,
Does your Mini no longer drift left after the wheel alignment?
Old Sep 23, 2024 | 08:00 AM
amatorMechanic
Hi njaremka,
Thanks for your response.
Here are some diagnostic codes I have recorded via scan tool in respect of DSC after the wheel alignment:
5DE7, 5E52, 5E34, 5DFB
Steering Angle remains constant at -0.12 degree while driving
Status ASC/DSC Not Pressed (No change whle driving)
The following parameters change on starting the car for 5 to 10 seconds while driving.
- Longitudinal Acceleration
- Traversal Acceleration
- Yaw-Angle Speed
After 10 seconds, the Longitudinal Acceleration changes but the other 2 shows 0. As if the mesurements stop altogether.
ps1. SZL Module Squib Switch Cluster has been changed recently.
ps2. The dash lights are also on as per photo.
Thanks.
Amber Dashlights are on while the engine is running
Old Sep 23, 2024 | 08:01 AM
amatorMechanic
Yes, still drifts to the left.
Old Sep 23, 2024 | 08:43 AM
Maybe, maybe not
Community Builder
Hmmm...did the shop provide the before and after alignment numbers?
Old Sep 23, 2024 | 11:07 AM
amatorMechanic
Alignment, Before @ After
Yes,
Please see the photos.
Old Sep 23, 2024 | 12:43 PM
Maybe, maybe not
Community Builder
The before alignment numbers would not have predicted any (leftward) pull of the steering wheel.
Edited:
I don't know your DSC control module variant.
If your DSC variant happens to be DSC_56 (my best guess), the DSC codes (https://bmwfault.codes/) would indicate the following faults:
(1) DSC control module
(2) Adjustment error in DSC steering angle sensor
(3) SZL (steering column switch cluster) signal fault to DSC interface
stinkerbell
Mar 23, 2023 09:29 AM
mzanden
Dec 21, 2010 08:06 PM
sdv515
Jul 22, 2006 09:30 PM
Jeffy
Suspension
18
Nov 7, 2005 08:32 PM
Guest
Sep 1, 2005 09:12 AM
