Mystery port on intake
Old Sep 13, 2024 | 05:39 AM
idickers's Avatar
idickers
I have a 2009 Clubman S that has been giving me fits to correct an intermittent stalling problem (Original problem). This is after pulling and reinstalling the engine, so I’m hunting for things I might not have reconnected. I noticed on the intake manifold that there is a port that is not hooked up (yellow arrow in pic). This isn’t coolant, as there is no leaking. is this a vauum port that I haven’t hooked up? I cannot find any hoses that are not connected, and I can’t find the connections on realoem.
Old Sep 13, 2024 | 06:07 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
This question comes up every now and then... That is a blind port that is not used on US vehicles. That port is only used in other markets.
I am going through your other thread now...
Old Sep 13, 2024 | 06:26 AM
Yep dummy port for the MINIs. Shared intake with PSA France, their is two different version.
https://www.northamericanmotoring.co...ding-part.html
Regular:
https://www.ecstuning.com/Search/Sit...h/11617595077/
Old Sep 13, 2024 | 07:16 AM
idickers's Avatar
idickers
Thanks for the clarification. Unfortunately, I was hoping this would solve my other issues, but I guess I can rule this out now.
Old Sep 13, 2024 | 07:33 AM
Yep,
I have seen the factory intake manifold get hairline cracks at the seam near the throttle body connection.
https://www.northamericanmotoring.co...ody-codes.html
Old Sep 13, 2024 | 07:42 AM
idickers's Avatar
idickers
Rats, looks like I’ll have to check the intake manifold more carefully. I was getting MAF implausibility codes which might make sense if there was a crack in the intake.
The weird thing is how this seems to only occur when the engine has run and been stressed. I can sit and idle for half an hour with no problem, but if I take out and drive it for 20’ and come home it will not restart and run. Instead, it bogs and stalls after starting, even when adding more throttle.
Old Sep 13, 2024 | 08:54 AM
Yep got to check that also.
Old Sep 13, 2024 | 09:42 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Sounds to me like a heat related issue....
MiniManAdam
Nov 19, 2024 05:35 AM
gimmea250swb
May 7, 2022 01:11 PM
nickbmw
Cooper (non S)
Apr 7, 2013 12:17 PM
slapshot591
Sep 5, 2010 10:33 PM
lamia
Want to Buy - All Other Items (archive)
12
Jul 20, 2008 07:29 PM
