R60 R60 diverter valve no shift at wot
Just installed the ecs diverter valve spacer yesterday. Everything seemed to be good and today I went full throttle through 2nd gear and it just stops at the shift point and holds the rpm there. Runs fine in sequential mode. Any ideas?
Automatic? Paddle shifting.
Weird, the DV spacer just lets off the boost. If the factory DV sticks or goes bad it throws a code.
The stumble of shift seems like a transmission issue. See if you can use the schwaben scan tool and pull a code, sometimes those codes dont come up when the CEL light comes one.
https://www.northamericanmotoring.co...-problems.html
https://www.northamericanmotoring.co...over-revs.html
https://www.northamericanmotoring.co...ng-issues.html
Make sure its not doing this:
Some people change the fluid first. I would see if you have some internal MINI codes also. https://minicooperforums.com/forum/0...mission-12881/
That could happen, they like to tear when touched. Older design likes to act up also.
Newest design here:
https://www.northamericanmotoring.co...om-intake.html
Newest design here:
OK glad to help, hope that it.
I heard of issues with sticky wastegates on the n14 and n18 turbos. Thus you cannot get into full boost and it cuts out on WOT pulls. Then at some point you will throw a CEL. It was a problem with the early N18 turbos.
https://www.northamericanmotoring.co...wastegate.html
Countryman97s
Feb 21, 2017 03:35 PM
