R56 Footwell module
Old May 8, 2024 | 06:16 AM
Yngbld14's Avatar
Yngbld14
Footwell module
Car is driving me crazy. Drove perfect yesterday. Get in the car this morning and bam. Tons of errors. Car is too temperamental. I believe the FRM is bad or needs to be reprogrammed. Does anyone know what it may cost?
Old May 8, 2024 | 09:11 AM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
Did your battery discharge? FRM show any water damage?
Old May 8, 2024 | 09:35 AM
Yngbld14's Avatar
Yngbld14
No. Battery didn’t discharge as far as I know. The car started right up like any other day. Everything is dry.
Old May 8, 2024 | 09:46 AM
Maybe, maybe not
Community Builder
If you clear all codes, do the codes and light issues return?
Also, you may need to remove the FRM and inspect it and the connectors for corrosion.
Old May 8, 2024 | 10:53 AM
Yngbld14's Avatar
Yngbld14
I can get rid of them, but they come back immediately. I will park it, pull the module out and inspect it later. I’m wondering if I should or shouldn’t disconnect the battery to do this.
Old May 8, 2024 | 12:22 PM
Maybe, maybe not
Community Builder
Yes, to be safe, disconnect the negative (-) battery connector.
Old May 13, 2024 | 08:43 AM
Yngbld14's Avatar
Yngbld14
So I pulled the frm module this weekend and there are no signs of water damage at the pins or connectors. I opened the module up and there are no signs of water intrusion at all.
Old May 13, 2024 | 11:10 AM
Maybe, maybe not
Community Builder
What year & model Mini?
Old May 13, 2024 | 11:58 AM
Maybe, maybe not
Community Builder
You may want to focus entirely on code 9CAA as it may explain all of your FRM problems. A blown 40A fuse (In A4010 Junction box, behind kick panel trim in right footwell?) might be the prime suspect. Click this link.
Old May 13, 2024 | 04:31 PM
Yngbld14's Avatar
Yngbld14
2007 MCS. Checked all the fuses and they’re all good.
Old May 13, 2024 | 04:53 PM
Maybe, maybe not
Community Builder
How did you check the fuses?
Old May 13, 2024 | 04:55 PM
Yngbld14's Avatar
Yngbld14
Pulled them out and ran a continuity test with a meter. All test good.
Old May 13, 2024 | 05:04 PM
Maybe, maybe not
Community Builder
It's more informative to voltage test fuses. Turn the key on and then measure voltage to body ground at both of the top test tabs of each fuse, especially the footwell fuses. All fuses should have near battery voltage on both tabs.
Old May 13, 2024 | 05:18 PM
Yngbld14's Avatar
Yngbld14
Can this be done without the frm module out? Or should I put it back in and check the voltages?
Old May 13, 2024 | 05:19 PM
Maybe, maybe not
Community Builder
Reinstall the FRM and verify that problems still exist. If so, do voltage tests. Write down voltage readings and compare to battery voltage.
Old May 13, 2024 | 05:32 PM
Yngbld14's Avatar
Yngbld14
I don’t see fuses 52 and 53. Not even in your picture. Where are they located?
Old May 13, 2024 | 06:04 PM
Maybe, maybe not
Community Builder
This is the correct fuse box for your car. Looks like your '07 has those two footwell fuses at F47 and F48. The third footwell fuse is at F5.
Old May 13, 2024 | 06:22 PM
Yngbld14's Avatar
Yngbld14
Ok. So you want me to test the voltage on both of the little tabs on fuses #5, #47 and #48. Correct? I’m basically checking voltage across the fuses and comparing it to the battery voltage itself.
Old May 13, 2024 | 06:29 PM
Maybe, maybe not
Community Builder
Correct. Also include F8 in the tests.
Old May 13, 2024 | 06:44 PM
Yngbld14's Avatar
Yngbld14
Ok. I’ll check the voltages tomorrow when I get home from work. 5,8,47 and 48. Thanks for all the help. I wanna make sure if it’s the FRM before I have to ship it out to get reprogrammed.
Old May 13, 2024 | 06:58 PM
Maybe, maybe not
Community Builder
Based of code 9CAA, you may find that the problem is a failure of voltage from one of the 4 footwell fuses to reach the footwell module rather than a faulty footwell module.
Old May 13, 2024 | 07:13 PM
Yngbld14's Avatar
Yngbld14
If that ends up being the case how would we fix that? Thinking JBE or a wire issue?
Old May 13, 2024 | 07:20 PM
Maybe, maybe not
Community Builder
If the problem is a broken wire, then running a new wire could be a solution as would repairing the broken wire. There are other possibilities, but additional electrical troubleshooting should reveal both the problem and fix.
Old May 13, 2024 | 07:32 PM
Yngbld14's Avatar
Yngbld14
So it still could be a possibility of a corrupted footwell. Or maybe a JBE issue. Or getting power to the 30b. I guess the only way to find out is start chasing down all the electrical. Seems weird that everything was fine the day before. Then it sat overnight in the pouring rain ( which it has before). I started the car the next morning and it was fine. As soon as I turned the headlights on because it was still raining, she started chiming atleast 10x. Really over engineered.
Old May 13, 2024 | 08:06 PM
Maybe, maybe not
Community Builder
As mentioned, based of code 9CAA, I'm compelled to focus on a failure of voltage to reach the FRM from one of the four FRM fuses. In this scenario, the problem could be caused by:
1) A bad FRM fuse or bad junction box fuse panel (A4010)
2) A broken or shorted power wire between A4010 and the FRM.
3) A bad or corroded terminal in a FRM connector carrying one or more of the 4 power wires.
4) A bad FRM terminal that connects to one of the four power wires.
