R52 Redyed my convert top
Old Mar 17, 2024 | 01:37 PM
Hotshoe1958's Avatar
Hotshoe1958
Decided to try redoing my blue convertible top. Bought some Rit dye on Amazon $3 A bottle got 3 in case one wasn’t enough .
Washed it twice. The directions said to mix it with hot water. But ignored that mixed it with room temp water and while thoroughly wet I had a dollar store sponge squeegee and applied dipping the sponge on the wet top. Washed the blue dye off the car and did the regular wash and dry on the body. It turned out better than I expected. Cost $3 and elbow grease.
Like new again picked Azur blue Rit dye.
Old Mar 18, 2024 | 12:27 PM
Very nice! Now treat it with some protectant and should be good.
Old Mar 18, 2024 | 07:18 PM
Hotshoe1958
Thanks,Yes I was thinking of a good water repelling spray on. Can’t believe a Cheap fabric dye would work as good as that expensive British convertible dye.My Mini sits In south Florida outside and takes a lot of abuse.
Old Mar 19, 2024 | 06:51 AM
Yep in FL and down south we see fade, not so much up here. Top protectant. https://www.northamericanmotoring.co...d-outside.html
Old Mar 19, 2024 | 07:19 PM
RB-MINI's Avatar
RB-MINI
Looks great!
Do you have a before pic?
I’ve been wanting to do this on a black canvas top but wasn’t sure if it would work or what it might do to the plastic window. I have an idea how to possibly mask the plastic protect it, but not sure if it will be a liquid tight seal, and/or if it will damage the window as it’s about 34 years old now.
Old Mar 19, 2024 | 07:48 PM
Hotshoe1958
This is a 4 year old pic, it’s the only good one of the top.
Yeah if you do a good job shouldn’t be a problem. The Rit dye that got on my car was easy to rinse if you do it right away. The color I chose was pretty dead on.
Old Mar 20, 2024 | 06:24 AM
RudeJoe's Avatar
RudeJoe
Nice cheap solution. I wonder how it will hold up to UV/fading?
Old Mar 20, 2024 | 06:06 PM
Hotshoe1958
Scothgard looks good with uv protection.
squawSkiBum
Detailing 101
11
May 13, 2017 08:47 PM
escamar03
May 5, 2014 03:23 AM
that7guy
Mar 22, 2008 08:12 AM
Blue Brummie
Detailing 101
19
Jul 4, 2004 06:09 AM
Nomonstersinme
Apr 1, 2003 05:13 PM
