R55 Where is the ambient air sensor?
Old Jan 31, 2024 | 05:48 AM
unclemiltie's Avatar
unclemiltie
My ambient air sensor is flaky. One day it'll be working fine and the next day it'll tell me that it's -40 out there. Guess it's time to replace it.
I've seen on line a couple of posts on replacing it but they're in different spots. One shows it behind the bumper cover that has to be removed to replace the sensor and one shows it in front of the fender liner on the right front wheel.
So where is it? 2012 Clubman S
thanks
Old Jan 31, 2024 | 05:56 AM
Touring1914's Avatar
Touring1914
I have a 2011 base. I was able to replace it thru the wheel well. Removed the tire then the front part of the liner. It's way in to bumper cover. Just pop it out/disconnect the electoral/ pop it back in. Getting to it was the most time consuming.
Forgot to mention, it's on the right side.
Old Jan 31, 2024 | 06:45 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
2012 Clubman S here, too. The ambient temp sensor pokes through a hole on the underside of the bumper, below the passenger side fog light. If you remove the passenger side front wheel, pop off the fog light access port cover, you'll see it down there.
Old Mar 3, 2024 | 12:52 PM
unclemiltie
To follow up. I pulled some stuff off and found that the wire had been broken and someone put some of those crimp-on connectors on it and they're obviously no good. This is why the intermittent temp readings.
So gotta get the soldering iron and shrink tubing out to do the job right. Unfortunately the soldering iron was at the other house so I have to put it back together to drive and will have to do the rapair some other time.
Briscoec
MINI E Talk (2010)
May 28, 2021 09:04 AM
Briscoec
May 28, 2021 08:28 AM
GoinCrzyWanaCom
Apr 29, 2013 03:21 PM
Yakatak
R55 :: Clubman Talk (2008+)
Nov 28, 2010 05:54 PM
SlikMINI
Sep 13, 2008 05:19 AM
