F57 :: Convertible Talk (2016+) Cooper and Cooper S convertible (F57) discussions.
F57 JCW PRO exhaust on a mini F57 09/2019 B48D
Old Dec 3, 2023 | 01:02 PM
jdfernandes's Avatar
jdfernandes
Only for a few months, according to the manufacturer, my mini does not allow the JCW PRO exhaust to be fitted.
The first MOD I did was to remove the OPF, which in my engine, does not have any associated sensor, and is just a physical part, at the beginning of the exhaust line after the downpipe.
I've seen in some videos, JCW after 2020 with the jcw pro exhaust. However, after some long research on some forums I was confused.
From what I understand, assembly is easy. The only problem I encountered was with the "electrical" part of how the button works to open and close the valve.
Has anyone here had this experience?
Best Regards
Joao Fernandes
Old Dec 4, 2023 | 09:58 AM
Button needs programed to work with the system. But also the wires and system has to be hooked up so the key fob can communicate with the system. Wire system has to be installed and have power.
https://www.northamericanmotoring.co...t-problem.html
Old Dec 4, 2023 | 02:25 PM
jdfernandes
Thank you for your help
But it is possible to work in a mini late 2019+, right?
Old Dec 5, 2023 | 06:58 AM
Yes, thats what people posted up it worked.
Old Dec 6, 2023 | 07:41 AM
Cableaddict's Avatar
Cableaddict
If you still can't make this work, you might have luck with the Dinan system.
It's very similar and costs less as well, plus they have great phone tech support.
Ezuke22
Nov 27, 2023 02:02 PM
smilly
Aug 22, 2023 11:55 AM
PrettyOfficerKidd
Oct 29, 2020 03:45 AM
nicholascanada
Sep 24, 2018 05:58 AM
YSoBlue
Jul 6, 2018 05:10 AM
