Only for a few months, according to the manufacturer, my mini does not allow the JCW PRO exhaust to be fitted.
The first MOD I did was to remove the OPF, which in my engine, does not have any associated sensor, and is just a physical part, at the beginning of the exhaust line after the downpipe.
I've seen in some videos, JCW after 2020 with the jcw pro exhaust. However, after some long research on some forums I was confused.
From what I understand, assembly is easy. The only problem I encountered was with the "electrical" part of how the button works to open and close the valve.
Has anyone here had this experience?
Button needs programed to work with the system. But also the wires and system has to be hooked up so the key fob can communicate with the system. Wire system has to be installed and have power.
If you still can't make this work, you might have luck with the Dinan system.
It's very similar and costs less as well, plus they have great phone tech support.
