Window Dip
Old Nov 17, 2023 | 04:27 PM
whittgu3's Avatar
whittgu3
Window Dip
Alright I've been struggling with this all day. I just replaced the outer handle on my driver door. This involves removing the door panel and the glass.
Once I got it all back together my window lost the auto functions. I reset it using the "roll it up and hold the button for 10 secs" I got my auto functions back, but...
THE PROBLEM: When I open the door my window rolls down about 1/16" of an inch instead of the 1/2" that it used to. The auto dip function is working, but not nearly as much as it used to. Is there a way to make it work properly again?
Old Nov 17, 2023 | 05:28 PM
Yoshimura 1's Avatar
Yoshimura 1
Keep bumping the window switch up to close the window with the door closed....I've done this when I did the same thing
as you....open the door afterwards then close hopefully yours work like mine.....
Old Nov 18, 2023 | 07:27 PM
whittgu3's Avatar
whittgu3
Tried bumping the switch a bunch of times, that didn't do it. Is there some kind of adjustment that I screwed up when I removed everything?
Old Nov 19, 2023 | 02:05 AM
Yoshimura 1
Have you tried adjusting the window regulator?
Old Nov 19, 2023 | 06:40 AM
whittgu3's Avatar
whittgu3
All I've done is held the up switch for 5-10 seconds after the window is up.
The weird part is that it's trying to dip, it just doesn't move as much as it used to.
Old Nov 19, 2023 | 02:23 PM
cooper48's Avatar
cooper48
Sounds like you might have reinstalled the glass a bit differently (maybe not fully seated).
Old Nov 19, 2023 | 05:31 PM
whittgu3's Avatar
whittgu3
Works Now
Today it just randomly started working. I've been using the car quite a bit, and I wonder if it just needed a bunch open-close cycles?
Old Nov 20, 2023 | 02:43 AM
Yoshimura 1
Once you disassemble it has to relearn the functions
Old Nov 20, 2023 | 12:16 PM
Reset here: https://www.northamericanmotoring.co...indow-dip.html
Then if that does not work, the window glass needs adjusted with the wrench.
https://www.northamericanmotoring.co...djustment.html
airbusA346
Mar 3, 2023 06:15 PM
climhazzard
May 2, 2021 07:07 PM
doxbike
May 16, 2020 11:01 AM
alconk
Mar 2, 2020 03:41 PM
Craig & Bertie
Aug 31, 2019 04:54 AM
