R56 OEM Rally Lights on 2013 Originally Equipped with Halogen Headlights now LED not work
Old Nov 14, 2023 | 02:14 PM
SevillianSTS's Avatar
SevillianSTS
EDIT: *************Disregard my question. Did not have the lights plugged in all the way 🤦‍♂️***************************
Hey guys, Have a 2013 MCS.
I bought an OEM Mini LED "Additional Headlights Retrofit" kit
Got it all wired up. Switch illuminates as it should. Green light turns on when pressed.
However I am getting nothing out of the rally lights.
My car was originally equipped with Halogen headlights. I have since installed the OEM Bi-Xenon retrofit kit, which required re-coding.
I originally wired the A1 wire to the Yellow/Blue wire on pin 4 of x14260 FRM connector; being my car was originally wired to handle halogens. That did not work.
So I changed the A1 wire to pin 41 of the same connector per the instructions for a Xenon equipped car. Still nothing.
I am guessing I am an odd case wiring these to a bi-xenon upgraded car and coding may have changed the rally light wiring requirements?
Old Nov 15, 2023 | 01:41 AM
Vanski's Avatar
Vanski
@SevillianSTS ,
Your footwell module may need to be reprogrammed to accommodate LED's since LED's have a different resistance values than halogens
2001f4s
Apr 22, 2024 08:54 AM
jk6221
Feb 26, 2020 03:47 AM
martinroger
Jul 29, 2015 09:50 AM
clintmeister
May 14, 2015 11:47 AM
spiney
Electrical
Dec 13, 2014 07:43 AM
