F55/F56 Retrofitting OEM LED Headlights
Old Mar 15, 2022 | 05:49 PM
2001f4s's Avatar
2001f4s
Hi, I've done a search and cannot find information on whether it is feasible to replace my standard halogen headlights with OEM LED headlights. I purchased a pair which include ballast, etc. and checked installation; plug is the same as the halogen, they mount the same way, but not sure if this will work as plug/play or even coded with Bimmer Code. Any input would be appreciated.
Old Mar 17, 2022 | 11:52 AM
thunderball kaboom's Avatar
thunderball kaboom
Here's two threads about retrofitting. It appears it's not plug-n-play (wiring loom differences and other issues), and prohibitively expensive (like nearly every other MINI retrofit).
https://www.minif56.com/threads/head...upgrade.64122/
https://www.northamericanmotoring.co...eadlights.html
I saw some non-OEM upgrade kits appear on a Google search, but they're from non-US sources.
Old Mar 17, 2022 | 12:41 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Those F56 headlights have a pretty big reflector. If you're comfortable opening the housings, I would put your money into this kit:
https://www.theretrofitsource.com/bi...LED?quantity=1
Old Mar 17, 2022 | 02:32 PM
michaelo's Avatar
michaelo
The halogen lights look the best and the lighting is great too. No need to change them.
Old Mar 18, 2022 | 11:01 AM
2001f4s's Avatar
2001f4s
Thanks all for the input. I will have to check out some of these options as my current halogen lenses have become foggy on the inside, and need to be replaced.
Old Apr 19, 2024 | 05:58 PM
figgy's Avatar
figgy
Where?
Hi and sorry to bring up this old thread, but where did you get these headlights?? I’ve been looking and can’t find these.
Old Apr 22, 2024 | 04:38 AM
michaelo's Avatar
michaelo
↑ These are the stock lights that come with the car. https://www.ebay.com/itm/23308953939...3ABFBMxJfO2eBj
Old Apr 22, 2024 | 08:54 AM
Some options here: https://www.northamericanmotoring.co...o-pre-lci.html
Mad Mini 19
Mar 13, 2020 10:35 AM
Thinker2112
Dec 28, 2016 02:14 PM
goneFXcrazy
Jul 8, 2016 12:34 PM
cowboy3500
May 25, 2011 10:47 AM
