R56 Vehicle No start No crank
Old Nov 8, 2023 | 11:19 AM
boucherjr's Avatar
boucherjr
So this am the wife came in and told me the mini wouldn't start / I gave her the other mini and she went to work. Yesterday it was fine no issues, I put the key in yes, in fact, doesn't start however the key on no start does work just nothing when pressing the button, Been doing a lot of reading, and a lot of troubleshooting people show different key issues which display on the vehicles display all which mine doesn't have the only key on the display that shows is a yellow picture symbol of a key no lines through or anything just a key, which I cannot find a meaning to anywhere. The vehicle is a 2009 and I am leaning towards the switch or the clutch safety switch as the starter and battery was changed a year ago. and last No codes were present
Also Is there a particular relay or fuse to check ? None of symbols provide useful information
Any help is appreciated
Old Nov 9, 2023 | 01:54 AM
Vanski's Avatar
Vanski
@boucherjr ,
The battery in your key fob could be going dead.
Old Nov 9, 2023 | 04:01 AM
boucherjr's Avatar
boucherjr
Originally Posted by Vanski
@boucherjr ,
Yes I thought that too however it locks and unlocks the car with no issues, I may swap it out and see a cheap sanity check
Update
Not as cheap and easy as I thought, I looked at the key, and my gosh! Why sell a car with a fully sealed key FOB, unbelievable
Old Nov 9, 2023 | 12:09 PM
The start stop switches sometime go bad and cannot receive the key. https://www.northamericanmotoring.co...-position.html
https://www.ecstuning.com/Search/Sit...h/61359299332/
Old Nov 10, 2023 | 02:11 AM
Vanski's Avatar
Vanski
If it locks and unlocks, that would mean that your fob may need to be reprogrammed by a dealer. But still, it's a good idea to have the battery replaced.
Old Nov 16, 2023 | 08:46 AM
boucherjr's Avatar
boucherjr
Diagnosing this car is a Pain, Had the DME and CAS tested with keys, and they are good to go, they stated there was a code for the steering column to be unlocked I didn't see the light for that but it could of happened when I swapped the Ign switch . To the forum any ideas
Old Nov 27, 2023 | 05:21 AM
boucherjr's Avatar
boucherjr
Fixed it, the ribbon between the switch and CAS was the culprit
06r50w10
Oct 26, 2023 04:45 AM
kromerok
Jan 18, 2018 05:30 PM
igorfpv
Nov 11, 2009 06:52 AM
Huligan
Oct 21, 2005 03:46 PM
