R55 crank, won't start with code Fuel-level sensor
N14 engine.
Scanner shows 2D52, DME: Super knocking
I pulled fuel pump fuse F46 out and run engine to empty fuel till engine stopped by itself. The fuel gauge shows 3/10 tank fuel.
Unhook the battery negative. I removed Intake manifold and cleaned intake ports which had huge carbon residues. After I assembled all intake manifold, and parts together, I may crank engine however it won't start.
Run OBD-II scanner, there are new DTCs related to Fuel level sensor.
ID:1, Engine electronics DME, Fault|5
DID:2755, Description: DME: Fuel-level sensor
DID:27C4, Description: DME: Fuel-level sensor
ID:9, Instrument cluster KOMBI, Fault|2
DID:9319, Description: Instrument panel: Fuel level sensor, left
DID:931A, Description: Instrument panel: Fuel level sensor, right
ID:15, Junction Box electronics JBE, Fault|2
DID: A6E4, Description: JBE: Fuel level sensor, left
DID: A6E5, Description: JBE: Fuel level sensor, right
Any suggestion to fix the issues?
Kalibdor
Aug 26, 2016 04:58 PM
