Drivetrain 03 MCS stumbles on start
Old Jul 20, 2023 | 09:58 AM
frankiev's Avatar
frankiev
Could use a little help with my 03 MCS . Had an issue a few days ago. When starting ran really rough , like only 1 or 2 cycl were firing . After sitting it started great with no issues.
Yesterday it happened again only this time stumbled and stalled a few times a
nd then nothing ... crank but no start. When I turn the key to position 2 I hear the fuel pump but only the first time. There's no more fuel pump sound after that initial time
Seems to be a fuel issue so the question is where to start . Does this sound like the pump is dying or maybe fuel filter or pressure regulator? Any help greatly appreciated
Old Jul 20, 2023 | 10:18 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
How many miles on the vehicle? Change anything recently? Ever change the fuel filter?
Old Jul 20, 2023 | 10:44 AM
Xplct's Avatar
Xplct
Had the same issue with my 03 MCS JCW last month, replaced both fuel pump and filter at same time, super easy to do. Runs like a champ now.
Old Jul 20, 2023 | 11:19 AM
frankiev's Avatar
frankiev
166k . I changed the filter at about 103k .
Old Jul 20, 2023 | 11:20 AM
frankiev's Avatar
frankiev
I ordered a pump and filter . Was it difficult to change the pump . I know the connected hoses can be a pia
Old Jul 20, 2023 | 12:13 PM
You will need the pre 7/2004 fuel pump of the R53, Just make sure you get the correct one. https://www.ecstuning.com/Search/Sit...h/16146766177/ The filter is a bit of a pain, but can be done: https://www.northamericanmotoring.co...er-change.html
Old Jul 20, 2023 | 01:22 PM
frankiev's Avatar
frankiev
Thank you
Old Jul 20, 2023 | 01:25 PM
Xplct's Avatar
Xplct
IMO. The pump was easier, than the filter. But then again I’ve never done either before this.
Old Jul 20, 2023 | 01:26 PM
frankiev's Avatar
frankiev
Is there a diy for pump replacement
Old Jul 20, 2023 | 01:37 PM
https://www.northamericanmotoring.co...placement.html
Some have a green top and some newer years have the white top.
Old Jul 20, 2023 | 02:14 PM
NC TRACKRAT
Veteran: Navy
If, when you access the filter and find it clogged, there may be trash in the tank as well. If so, think about where you get gas and re-evaluate.
Old Jul 20, 2023 | 02:21 PM
frankiev's Avatar
frankiev
Awesome . Thank-you
Old Jul 21, 2023 | 06:41 AM
Welcome.
sudmanster
May 25, 2022 03:26 PM
B dub
16
Oct 31, 2019 10:12 PM
bralston9
Jan 28, 2015 06:45 AM
NC Doug
Dec 3, 2012 01:39 AM
-=gRaY rAvEn=-
Jan 19, 2011 03:57 PM
