R56 R56 Oil Cooler Kit
Old May 27, 2023 | 10:04 PM
Jas0123's Avatar
Jas0123
R56 Oil Cooler Kit
Hi,
I have recently installed an oil cooler kit.
Question is do I need a high volume oil pump to have the oil flowing or oil pressure consistency?
thank you
Old May 29, 2023 | 06:33 PM
Coz3z3's Avatar
Coz3z3
You shouldn't need a new pump. What kit did you get? I kick myself for not getting the Sneed kit when they were in business. I can't find another adapter that has the oil temp port built in.
Old May 29, 2023 | 09:13 PM
Jas0123's Avatar
Jas0123
I got some brandless one through AliExpress. As my comes without the thermostat, was worried that the stock pump doesn’t have enough oil volume to have it pump to flow through the oil cooler as it’s running differently from the standard stock settings.
Old May 30, 2023 | 05:25 PM
Coz3z3's Avatar
Coz3z3
Should be fine. I have never read of needing a bigger pump for it. I don't even know if one is available. I have never seen one talked about. And even so, depending on cooler size, you are probably only adding about another quart to the system.
Old May 31, 2023 | 08:40 PM
Jas0123's Avatar
Jas0123
Alright, thanks mate.
Dead Ringer
Mar 17, 2010 05:21 PM
gtbuzzmini
Classic Mini Talk
Jul 1, 2006 12:25 PM
rrdusek
Apr 17, 2006 05:15 PM
