R56 Cravenspeed automatic shift knob
Old May 23, 2023 | 11:13 PM
Dmads's Avatar
Dmads
Cravenspeed automatic shift ****
Ended up needing a different part in the kit, cravenspeed customer support reached out and shipped me the new part.
Hopefully I update this post with successful results!
New part arrived and fit like a glove, shifter works great.
Old May 24, 2023 | 04:37 PM
Yoshimura 1's Avatar
Yoshimura 1
It looks like the top of the shifter shaft is a little ruff........try cleaning it up and see if the shift **** fit's smoothly....
Then repeat the install steps and rotate the shift collar to line up with the holes and install the screws....
Old May 24, 2023 | 04:50 PM
Yoshimura 1
I'm also seeing that per the install guide they have the car in neutral when installing the shift rod......
What gear are you trying to install the shift rod in maybe any other gear doesn't allow the rod to be
seated any lower at the correct depth.......
CravenSpeed
Aug 6, 2025 10:30 AM
madmax88
Feb 7, 2014 07:53 PM
cumang0
Jan 11, 2014 10:48 AM
nattanont
Sep 15, 2013 05:27 PM
enologuy
Aug 27, 2007 08:53 PM
