Limp mode initiated with Boost ?
Old May 14, 2023 | 04:46 PM
sm-allmini's Avatar
sm-allmini
2013 Mini Cooper S n18 engine 90K miles. As soon as boost builds the engine kills to an Idle and will not rev past 2K. I have to restart motor and will run good until I hit boost again. My scanner reads no codes given. The dash shows check engine light for a few seconds, then clears. Things I have replaced to solve issue: Replace fuel pump and fuel pressure sensor. I have checked the fuel lines in engine bay, they seem good.
Anyone have suggestions ?
Old May 15, 2023 | 03:49 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
For sure there has to be codes stored for these events. Your scanner just isn’t pulling them. What scanner are you using?
Old May 15, 2023 | 09:33 AM
Gubi's Avatar
Gubi
It could be a bad diverter valve. The original version was prone to tears which would cause boost leak. There's a revised version that's supposed to be more durable.
Can't say that's definitely your problem but given the age of your car it wouldn't be a dumb idea to replace it with the uprated version if it hasn't already been done.
Old May 15, 2023 | 07:18 PM
sm-allmini's Avatar
sm-allmini
I use OBDLink app on my phone with a OBD dongle. It is supposed to be good for BMW codes. Maybe not so much.
Old May 15, 2023 | 07:21 PM
sm-allmini's Avatar
sm-allmini
As soon as I bought the car I changed the diverter valve to a turbosmart 50/50. It may be failing/defective. I ordered a new stock one. I will see if that solves the issue.
Old May 16, 2023 | 03:38 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
It could be due to the TurboSmart valve. Here are a couple threads with others having issues with them:
https://www.northamericanmotoring.co...stion-n14.html
https://www.northamericanmotoring.co...dual-port.html
greeeeb
Feb 9, 2023 02:39 PM
CooperCrazy333
Apr 13, 2021 07:31 PM
tcmcs
Sep 17, 2019 05:48 PM
Jonny Crisp
Mar 31, 2017 10:57 AM
SoundMessage
Aug 16, 2013 06:44 PM
