R56 Post engine bay Fire, wiring harness coming from firewall toast
Old May 2, 2023 | 10:59 AM
IDrive55's Avatar
IDrive55
Ok, my car is a full time track car. R56 Turbo S. I think this is the worst thing that can happen next to an actual crash. Long story short, oil leak led to engine bay fire. Engine wiring is toast, but real easy to replace. The fire took out ECU and Fuse block and the connectors to them. That means wiring moving to front driver side as well as down to transmission and power steering. I have located wiring for everything but the connectors back to through the firewall. I stripped everything out as well as dash and I am overwhelmed that it looks like I will have to replace ALL of the wiring in the car as it appears as it is one piece. I thought I could replace the harness from under dash to the engine but I cannot see connectors seperating the two. Anyone have ideas of whether you an purchase a complete main chassis and dash wiring harness? the car is structrurally perfect, but I need to figure out how to solve this. I am overwhelmed.
Old May 2, 2023 | 11:30 AM
tbmguy's Avatar
tbmguy
I believe ECS Tuning has some engine harnesses, they are genuine Mini.
search by vehicle and type in "harness" then scroll till you see it.
Old May 2, 2023 | 11:33 AM
IDrive55's Avatar
IDrive55
I already got that one. I need a main or chassis harness.
Old May 2, 2023 | 01:02 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I think your best bet might be to find a salvage R56 of same vintage and swap harnesses.
Here is the main wiring harness, which retails for ~$4000:
https://www.realoem.com/bmw/enUS/sho...diagId=61_1969
You could probably find a salvage R56 with many more usable parts for much less than $4000. Would make for a good race parts car.
Old May 2, 2023 | 01:44 PM
Yoshimura 1's Avatar
Yoshimura 1
Absolutely look for another parts vehicle for what you're going to need.
Maybe swap over everything to that one and start with a clean slate....
Old May 2, 2023 | 01:57 PM
IDrive55's Avatar
IDrive55
I appreciate the comment, I actually found a donor mini for $2,500 but it is overwhelming what has to be done to get the chassis and dash harness out of an old car. The engine compartment is easy. but the connectors and harness that go from the engine bay back through the firewall into the car does not disconnect from the chassis. It is one big harness. My car is a full race car. There is no interior or sound tape, nor dash. But a street mini has the whole world in it and it ALL has to come out. Crazy!
Old May 2, 2023 | 02:00 PM
IDrive55's Avatar
IDrive55
I already have the parts vehicle. However, the question is what is harder? Taking all the mechanicals out of the race car and transfer to a stock mini just because it has a good harness? I mean fire suppression, and cage alone would take a few thousand to have someone cut up and re weld it into the car. Engine, transmission, cooling, suspension, exhaust yadda yadda. Both options are insane.
Old May 2, 2023 | 08:13 PM
Yoshimura 1
Well, I have taken the entire harness out of a vehicle and that was a real task.......The engine harness is super easy and quick.....
​​​​​​​The main harness is one whole unit and there isn't any plug connections to separate it....
Old May 2, 2023 | 08:15 PM
Yoshimura 1
Even removing the entire dash isn't hard at all to remove....
Old May 3, 2023 | 07:29 AM
IDrive55's Avatar
IDrive55
Yup, that is what I found out. I could spend $4000 on a harness already out of a car, or buy a donor and do it. I chose the donor. I just did not know what I was getting into. However, it is a super clean donor. I think I can make quite a bit back on parting it out. I shall see. I think my summer will be spent removing the harness out of the donor. Getting it back into my track car will be super easy. It has no interior but the full cage and race seats. Might even be an opportunity to clean it up and repaint the interior. Have to find a bright side.
Old May 5, 2023 | 03:46 AM
Yoshimura 1
I have one that I removed from a 2013 R56S that thing was a royal pain.......Lol
after all said and done I put it in a heavy-duty black plastic bag for future use
​​​​​​​I suggest for easier reassembly put a little tape and paper for reconnection
location.
That harness is spread out in the vehicle like an octopus.
jk6672
Electrical
Sep 27, 2021 11:02 PM
Chey Horton
Nov 14, 2020 05:52 PM
Yoda Mini
Nov 10, 2016 04:28 PM
Jemo
Classic Mini Talk
Nov 23, 2008 08:11 PM
d_r_young
Jul 11, 2007 10:16 AM
