F55/F56 Digital gauge cluster not fitting
Hi all, just curious as to whether others have had issues installing the digital dash into their pre 2020 cars, I have a 2019 cooper s and have tried to put the new cluster in however the base plate seems to be catching with only the right hand side screw hole aligning, any ideas or recommendations would be greatly appreciated.
thanks, Max
thanks, Max
I have made the cluster fit. It just need some further gentle persuasion. However after coding the car is now throwing a check drive train soon error but it drives just fine, from what I understand bmw cars tend to do this when you change coding, is this correct or should I be concerned ?
You haven't said what tool you're using or whether the code returns after clearing, so can't really tell you whether you are dealing with the same thing or not. If the code is returning after being cleared I would be concerned.
