Suspension Lifted R60 S ALL4
Old Jan 4, 2023 | 05:10 AM
KIC07's Avatar
KIC07
Lifted R60 S ALL4
Lifting my 2016 countryman. I found a couple different lifted coilover setups. Ceika and flat out suspensions. Does anyone else have any other ideas of quality coilovers they've used to get a 2-3 inch or higher lift? Also has anyone had to get different control arms or longer sway bar end link's for their coilover lift?
Old Jan 5, 2023 | 07:43 AM
You can run the lifter M7 Speed R60 kit spacer version and Kit the suspension stock then go with a Bilsteins or KONI? Unless you really want the coilover set up to dial in. Some people will get stock coilovers from their favorite brand coilover and then you can dial down and get ones with dampening (with i would do). As far as lift over stock most aftermarket coilovers will go up a little like ~10mm over stock. But thats the most you will get in lift.
Then you can get bigger tires and get this set up below. https://www.northamericanmotoring.co...ntryman-2.html
https://www.northamericanmotoring.co...-2-5-lift.html
https://www.ecstuning.com/b-m7-speed.../c-suspension/
Hope that helps.
danielegangichiodo
Dec 2, 2021 03:10 PM
Schmeichel
Oct 16, 2020 11:52 AM
Steven Xie
Jun 15, 2020 10:37 AM
ntubeusa
Mar 18, 2019 04:36 AM
jaclx
Sep 10, 2017 03:51 PM
