R50/53 Piston help R53 W11
Old Oct 9, 2022 | 06:12 AM
ttawfik3's Avatar
ttawfik3
Piston help R53 W11
My block has 184k. I am planning within the next couple months to rebuild the whole engine including rings, rods, pistons, etc. I am looking for more power through this rebuild of course. So good brands, tips, tricks, rules, etc are what I’m looking for. Let me know how I should start this project and what procedures I follow. I only replaced my head with an rmw head so I am a newbie to rebuilding engines so any information is appreciated. Thanks!
Old Oct 9, 2022 | 11:27 AM
Nervos's Avatar
Nervos
Before buying any parts you'd need to fully disassemble the engine, measure the cylinders in the block to determine if you need to bore them or not, and therefore - if you need a plus size pistons or not. Or, you can just buy another block and work on it.
Forged pistons / rods will cost you an arm and a leg. Pistons themselves will cost you 550 - 850, plus ~450 for forged rods. Check the www.sneed4speed.com
Old Oct 11, 2022 | 02:36 PM
BlwnAway's Avatar
BlwnAway
^^ This ^^
You may end up needing less than you think, my cylinder walls still had cross hatching at 213k
Old Oct 11, 2022 | 11:38 PM
mr.r50's Avatar
mr.r50
Make sure you don’t buy fel pro for head gasket or studs , learned the hard way
Worst
Old Oct 31, 2022 | 04:49 PM
ttawfik3's Avatar
ttawfik3
Worst
If only I saw this post 3 months ago. I installed my rmw head with a felpro gasket and blew it right when I cranked it resulting in an overheating engine. Thank the lord I did not manage to warp my head. Grabbed a $110 gasket that MiniMadAdam sent me and redid the whole job, installed it yesterday and it went perfectly.
Old Oct 31, 2022 | 07:11 PM
Husky44's Avatar
Husky44
Give some serious, consideration to buying a Remanufactured short block from a reputable supplier.
By the time you buy all the parts and do the machine shop work, you may be the same price, or cheaper.
Old Nov 1, 2022 | 05:56 AM
Here2Go's Avatar
Here2Go
NAM Community Team
Yes - Definitely something to consider.
The operative word here, being = REPUTABLE.
In my previous (non Mini) experience - I'd made that mistake ONCE (based on lowball price).
Old Nov 2, 2022 | 11:16 AM
Rebound's Avatar
Rebound
oh no, I just replaced my timing cover gasket with a Fel-pro. I hope it doesn’t blow up on me.
Old Nov 24, 2022 | 06:13 PM
2out2sea's Avatar
2out2sea
So in relation to my other thread. Who is the reputable engine builder? I'd go with any of the stand bys, rmw, thumper, way, etc. Some are hard to trust, some are asking far too much, others are just plain fickle and if you don't buy all of the parts from them they won't work with me. If there's a definitive answer of the shop to use then...I really wish this was easy. Please advise in my thread.
Old Nov 25, 2022 | 07:11 AM
The Devil Z's Avatar
The Devil Z
Have your trusted local machine shop do it or do it yourself. Its actually straightforward once all the measurements are done. Dont want to do the measurements? Again Machine shop should do most of them when you bring them pistons fot p2w/bore. What pistons to get? I used and trusted the original engine engineer on that one. Alex designed a set that can be had.
Old Nov 26, 2022 | 02:17 PM
2out2sea's Avatar
2out2sea
We just moved here and I can't seem to find a machine shop closer than 70 miles away. Plus I wouldn't know if they are reputable. I guess back to square one. Thanks for the continued suggestions. I appreciate it.
Old Nov 28, 2022 | 12:48 PM
The Devil Z
Where are you?
Old Nov 28, 2022 | 03:31 PM
2out2sea's Avatar
2out2sea
Northwest corner of Montana. Six miles from the Canadian border. I think I've located a good shop in Spokane. It's about 3-4 hours from me which is doable.
Old Nov 28, 2022 | 08:05 PM
The Devil Z
Ok I am in western WI near the twin cities. I do get to the Dakotas in the spring.
Old Dec 9, 2022 | 12:24 PM
ttawfik3's Avatar
ttawfik3
So I actually got the chance to measure each cylinder and each cylinder is around 77.7-77.8mm. Is that good or is that a worn out cylinder and requires boring?
Old Dec 24, 2022 | 01:53 AM
ttawfik3's Avatar
ttawfik3
in looking at some pistons only. It’s a set which comes with the rings and the wrist pin lockers aswell. Also added rod bearings and arp rod bolts, came out to 559. It’s a sale online. It’s wiseco. So it’s a really good deal. Planning on just doing piston heads for now and than soon upgrading literally everything
Rowan212
St. Louis MINI Club
May 10, 2011 03:53 PM
002
Oct 30, 2007 05:51 AM
