2885 Code After Oil Overfill
Old Sep 6, 2022 | 04:00 PM
otterby's Avatar
otterby
I've been trying to figure out why my '12 R56 JCW keeps throwing the 2885 code (Charging pressure control deviation, plausibility). I've tried pretty much everything I've read in these forums with no success I remembered when the code first appeared it was immediately after I did an oil chance a couple months ago. I accidentally overfilled the oil by 1/2 to 3/4 of a quart. I drive the car a few miles and the CEL came on with the 2885 code. I drained the oil to the proper level and reset the codes but it now continues to reappear during hard acceleration. Is there any way these could be related? Could some oil have made its way to the cat and that is the source of my problem? Or maybe the PCV system? Any suggestions?
Old Sep 7, 2022 | 03:42 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
It could be entirely coincidental. That code usually pops up because there is a leak in the charge tubing somewhere, or the diverted valve is going out. Did you remove any piping for your oil change?have you pulled and checked the diverted valve diaphragm?
Old Sep 7, 2022 | 03:59 AM
otterby's Avatar
otterby
Thanks. I have replaced the diverter valve and have visually checked all of the piping for leaks with nothing found.
troyegly
May 28, 2021 09:47 AM
Ericfragola
Mar 8, 2018 08:01 PM
eaglebeagle
Jan 6, 2014 09:54 PM
rckrzy1
Dec 8, 2013 09:47 AM
boonefly
Oct 22, 2012 03:04 PM
