R50/53 Air Conditioning pressures - what are expected?
Old May 25, 2022 | 05:41 PM
AndrewVanis's Avatar
AndrewVanis
Air Conditioning pressures - what are expected? (SOLVED)
What are the Low and High side pressures expected? I'll be checking with a gauge set.
my first thread wondering about HVAC flapper issue may eliminate that as the reason for poor performing AC even though the low side is similar to that I'd expect on other cars. https://www.northamericanmotoring.co...ml#post4623163
Old May 25, 2022 | 05:56 PM
mini_me123's Avatar
mini_me123
I think I read 30/150. I did mine last week and couldn't hit those pressures (at idle). I had a tiny vac pump and at some point couldn't track refrigerant weight due to a leak. I eyeballed i to the correct vent temp though.
https://www.northamericanmotoring.co...tioning-431066
Old May 25, 2022 | 05:59 PM
AndrewVanis
Helpful link....in the temp table, which do they consider the center vent in "Center Vent Temperature"
Old May 26, 2022 | 11:23 AM
AndrewVanis
SOLVED. Turns out more refrigerant solved the issue. I was within specs on that chart and about 5psi higher got the cool air flowing.
jagster936
May 2, 2022 09:28 PM
Firefly1013
Sep 15, 2018 10:55 AM
lazabby
Jul 16, 2018 05:15 AM
cub4bearindiana
Jun 30, 2016 06:11 AM
friday9x
Jul 27, 2009 03:51 PM
