Suspension Alignment settings for track-daily
Old Mar 18, 2022 | 05:20 PM
r53racer's Avatar
r53racer
Hi NAM,
I just installed offset FCAB, Powerflex camber inner ball joints, IE fixed plates, Bilstein B6, Swift spec r springs. Attached shows the final alignment settings, the best the shop can do. I’ve read that for “set and forget” set the rear camber to half of what’s in the front. What do you guys think of my alignment settings? Should I be a bit concerned about the .2 and .3 degrees of of more camber on the driver side? Or is that difference too small?
Old Mar 19, 2022 | 04:45 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Since your front isn’t really adjustable, you pretty much have what you have. I would prefer more camber in the back for a daily driver. You really don’t want the back end coming about on your commute.
Old Mar 19, 2022 | 08:36 AM
r53racer's Avatar
r53racer
Is -3 camber not too much? I like how it turns in and how the rear steps out just enough, but I haven’t tracked it yet to tell. Is the difference between driver and passenger negligible?
Old Mar 19, 2022 | 01:42 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Yes, negligible IMHO. -3 degrees for track is awesome but for daily driving, not so much. -2 would be a good compromise but , as stated above, it is what it is.
Old Mar 19, 2022 | 03:07 PM
r53racer's Avatar
r53racer
Oh cool! Thanks NC! I’m glad to hear that -3 is awesome for the track as I had no idea what camber is track focused . I’m ok with compromising daily ability a bit. I’m going for 65%track/35%daily car.
Old Mar 19, 2022 | 08:15 PM
OCR's Avatar
OCR
The IMPORTANT part of this question...while YES, the right and left side SHOULD be different...
Do the side to side numbers come closer...with the driver IN the SEAT ?
When setting up my car (JCW, with stock shocks and aftermarket springs), with the help of a shop, I found that, with my car...the difference is about 1/3 (.3) of a degree difference, side to side, with me in the seat, vs. no driver weight load.
I set my car up appropriately.
The numbers that I used came about from several trips into the local canyons and checking the scrub on the tire tread. Verified a nice even scrub pattern, only myself in the car.
-1.5° front, -.75° rear
I've got Ireland Engineering parts at both ends.
Mike
Old Mar 20, 2022 | 05:50 AM
r53racer's Avatar
r53racer
Mike
Hey Mike,
I was actually thinking about that. So are you saying that when you get in the driver seat, the driver side camber decreases by .3? In my case, if you sat in my car, the driver side will go from -2.9 to -3.2 making it even with the passenger side granted there is no passenger?
Because the weight of the driver lowers the car and changes the camber by about .3? At least in your case? I’m just asking for more understanding, it’s not like I’m going full racing. And like NC said, the difference is small but it’s still nice to know. I understand these are theoretical as spring rates may vary and there are other variables.
Old Mar 20, 2022 | 06:02 PM
OCR's Avatar
OCR
Originally Posted by r53racer
Hey Mike,
Yes sir. We checked it a couple of times. Once before my adjustment, then after my adjustment, and his "computer" adjustment of the whole suspension.
Yes, again...only in ALL cases. Unless the driver is a REAL lightweight, and the car has heavy springs, the drives side will drop..."some"...amount. Again, depending on the springs and the drivers weight.
If you weight 150lbs, the car will not lower as much on the drives side as a driver that weighs 250 lbs. (same springs).
You just need to check the camber both driver weighted and driver out of the car, then adjust the camber accordingly. Unless you find a shop that will allow you to sit in the seat...while...they complete the adjustments, that's the best way to do it.
Many...years back in the manual adjustment days, I used one shop exclusively, because he let me sit in the car while he did the adjustments. Difficult to find these days.
Mike
Old Mar 21, 2022 | 05:57 AM
NC TRACKRAT
Veteran: Navy
I always get my alignments done with me sitting in the driver's seat.
Old Mar 21, 2022 | 11:41 AM
r53racer's Avatar
r53racer
Thanks NC and OCR. Looks like I'll have to look for a good shop that allows the driver in the car.
Old Mar 21, 2022 | 03:27 PM
veggivet's Avatar
veggivet
I think you will find the -3 camber up front perfect for the track, but possibly a little too much for regular driving. I wouldn't sweat the difference between driver and passenger side, as they'll likely equal out depending on how much you weigh.
micromini234
17
May 30, 2013 06:13 PM
Jack$0n
Factory JCW Talk (2009+)
Aug 17, 2011 06:22 PM
SimpsonGI
Mar 20, 2008 09:26 AM
RDut
Oct 9, 2007 09:05 PM
obehave
Suspension
16
Aug 17, 2006 12:19 PM
