F55/F56 F56 Transmission Mount DIY?
Old Mar 16, 2022 | 02:31 PM
2014MCS_Miami's Avatar
2014MCS_Miami
Im replacing both engine mounts per the dealers indication that they're no longer any good (82k miles on 2014 MCS Manual).
Wondering if I should do the Trans Mount as well? Cant seem to find anyone thats done it and no DIY's either.
What do you guys think, should I replace it?
Old Mar 18, 2022 | 02:26 PM
TVPostSound's Avatar
TVPostSound
Remove the battery and tray,
They recommend removing the axle, but you can work around not removing.
Remove bolt through wheel well
The rest is self-explanatory.
Old Mar 20, 2022 | 08:30 PM
2014MCS_Miami
thank you so much man!!
2014MCS_Miami
Quick question (maybe dumb), do I need to support the transmission or even lift it a bit with my jack?
Old Mar 20, 2022 | 09:08 PM
TVPostSound
yes
to both
Old Mar 20, 2022 | 09:11 PM
2014MCS_Miami
thanks!
Old Mar 26, 2022 | 04:59 PM
2014MCS_Miami
Originally Posted by TVPostSound
yes
to both
My car is all apart now and I removed all the bolts you mentioned. The trans mount is completely loose but absolutely wont come out because the transmission is in the way. I need to somehow lower the trans a few millimeters so the mount can slide out but nothing is working.
Any suggestions for me?
Old Mar 27, 2022 | 10:59 AM
2014MCS_Miami
To any home DIYers considering the Trans Mount replacement, don't. It's impossible to get it out because the transmission itself remains in the way. All I can think of is dropping the subframe slightly perhaps but honestly not even sure that would work. The bushing itself looks rather fine even after 82k miles on my 2014 (so 8yrs old as of this post). Im going to simply reassemble and leave it in there. Getting the battery tray out to access it was another nightmare as well. Why does such a tiny car need a 100lb battery???
The upper motor mount is DIY possible, if a bit involved and took me 5 hours thanks to VERY stubborn headlight bolt/clamp mechanism. I'll type up a DIY for that really soon.
The lower engine mount was easy as pie and can be done in less than an hour! I swapped in the Powerflex yellow bushing and the hardest part was cutting out the stubborn original rubber bushing. The rest was easy.
Old Aug 24, 2024 | 09:52 AM
ChrisHarris's Avatar
ChrisHarris
I saw someone else instructing to remove the headlight for removing/installing the transmission mount. That's not necessary either, is it?
I fully understand that you have to remove the headlight to get to the upper mount, but needing to remove the other headlight for the transmission mount sounds excessive to me. Is it perhaps just a bit helpful, or was that person likely overthinking it?
Illes Levente
Aug 27, 2024 12:09 AM
MattW
Jun 27, 2021 06:10 PM
Llanrhaeadr_Cymru
Aug 25, 2020 07:09 PM
cloudf56
May 10, 2020 02:44 PM
punkgeek
Feb 9, 2019 01:50 PM
