R57 Remove subframe mini cooper s
Old Mar 3, 2022 | 11:48 AM
kromerok's Avatar
kromerok
In order to remove the subframe from a 2014 r57 s do i need to do anything with the exhaust?
Old Mar 3, 2022 | 01:18 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Front or rear? Regardless, the exhaust goes under both subframes, so to remove either front or rear subframe, you will have to lower the exhaust.
Old Mar 3, 2022 | 02:22 PM
kromerok's Avatar
kromerok
Front, I cant seem to find a good video for removing subframe do you know of any?
Old Mar 4, 2022 | 03:35 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
What are you looking to do? Some tasks can be done just by loosening it a bit.
Old Mar 4, 2022 | 09:48 AM
kromerok's Avatar
kromerok
I was trying to get to the rear arm bushing, sway bar bushing and remove control arm
Old Mar 7, 2022 | 12:30 PM
TVPostSound's Avatar
TVPostSound
Heres a video that might give some pointers
Old Jul 26, 2022 | 04:26 PM
kromerok's Avatar
kromerok
Is it possible to remove the front exhaust clamp without a special tool. I saw in a video a pair of pliers that instead of contracting when squeezed expands but i cant find one in any stores in LA wondering how else its done then
Old Jul 26, 2022 | 04:32 PM
TVPostSound
Reverse pliers.
also known as bow opening pliers.
amazon or harbor freight.
where in LA are you.
Old Jul 26, 2022 | 04:36 PM
kromerok's Avatar
kromerok
Im in bh, i went to Harbor Freight earlier but i didnt know the name of tool so i went to automotive and just looked for something that reminded me of it but didnt see it. Let me try that name.
Old Jul 26, 2022 | 05:42 PM
TVPostSound
Old Jul 26, 2022 | 05:47 PM
TVPostSound
Amazon Amazon
Old Jul 26, 2022 | 09:49 PM
kromerok's Avatar
kromerok
Is it the long ring pliers?
Old Jul 26, 2022 | 10:25 PM
TVPostSound
Yes, the long pliers, that is what I used to open and install the olive connector.
Old Jul 26, 2022 | 10:39 PM
TVPostSound
Remove the bolt, and use the reverse pliers to spread the clamp.
Old Jul 26, 2022 | 11:07 PM
kromerok's Avatar
kromerok
Perfect, thank you.
Old Jul 27, 2022 | 03:48 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I’ve removed that clamp with two screw drivers wedged in between the ears
Old Jul 27, 2022 | 09:05 AM
TVPostSound
That works too, but using screwdrivers to reinstall is kinda awkward.
Old Jul 27, 2022 | 09:12 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I just man-handle it to reinstall
Old Jul 27, 2022 | 09:17 AM
kromerok's Avatar
kromerok
I bought the recommended part but will try to do it without it shortly to at least get it off.
Old Jul 27, 2022 | 10:32 AM
TVPostSound
Its easier on a 2nd gen, a 3rd gen its high up.
Old Jul 27, 2022 | 05:08 PM
kromerok's Avatar
kromerok
I successfully removed the clamp with needle nose pliers waiting on lca and sway bushing so i will have tool to reinstall when done. Does anyone know what kind of shop would have a press to remove and install the lca bushing is it easy to do at home?
Old Jul 30, 2022 | 12:46 PM
kromerok's Avatar
kromerok
Anyone know where i can get the torque specs for the subframe parts so i can start to reinstall?
Old Jul 30, 2022 | 01:18 PM
kromerok's Avatar
kromerok
Ended up cutting out the old bushing and jerry rigging a threaded bolt with two washers to press in new bushing used powerflex bushings
Old Jul 30, 2022 | 03:35 PM
TVPostSound
PM me your email
ill send you a newtis.com invite.
Old Jul 30, 2022 | 03:47 PM
TVPostSound
Since the subframe is down:
https://www.tunershop.com/h-r-sway-b...pe-370771.html
