R56 Tire size help
Old Dec 9, 2021 | 03:05 PM
Alexzannder's Avatar
Alexzannder
Tire size help
Hey all, I’m hoping for some anecdotal evidence stories from people who have changed tire size. I have the stock 17s on my car which are 205/45/17. I know that you are supposed to not go above a 3% difference in tire size.
but..
I want to move to a 205/50/17 which is 3.33% larger than stock. I am looking for a wider ranger of winter tires and have looked at 215/40/17 and 205/40/17 and although those sizes are within the 3% change they don’t seem to have much as far as winter options.
I know that stock size tires have a few winter options and I have tried two different types of studless ice and snow and was not super pleased with either. Where I live it is good to be on studded snow tires, even have them on my 4wd blazer (which is currently dying hence the looking for mini tires). 205/50/17 has 3 studdable options on tire rack so I would love to go with one of them.
Old Dec 9, 2021 | 08:21 PM
Jason Cornelius's Avatar
Jason Cornelius
Try looking at 215/45/17, there seems to be a lot of options there and that’s what I’m running.
Old Dec 10, 2021 | 03:48 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
For winter tires, consider a second set of 16” wheels, and go for 205/50-16 tires. For winter driving, you’ll appreciate the lighter weight. And you’ll save on having the tires swapped over twice per season.
Old Dec 10, 2021 | 10:31 AM
Alexzannder
have you had any issues rubbing or fitting them? Are you stock?
Old Dec 10, 2021 | 10:32 AM
Alexzannder
I thought about going to a smaller rim but I was lucky enough to get a second set of stock 17s for a very cheap price so rather than buying 16s I figured I’d use what I have.
Old Dec 10, 2021 | 10:45 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I currently have 215/45-17 winter tires on my OEM 17 inch wheels, and the are HEAVY. The OEM wheels are heavy enough, but when paired with snow tires in 215/45 size, OMG. If you absolutely have to run OEM 17" wheels for winter, stick with a 205/45-17.
For comparison, I have a set of OEM Miata 17" wheels with 215/45-17 Kuhmo tires, and they weigh in about 38lbs total. My winter set up of OEM Mini wheels and 215/45-17 Firestone Winterforce tires, and the set tips the scale at ~45-48 lbs! You wouldn't think 10 lbs would be that much, but the car is such a pig with the winter wheels.
Old Dec 10, 2021 | 06:23 PM
Alexzannder
I’ve wintered it with the stock 17s before and had no issues.not worried about the weight or anything, just looking for a better tire than the once’s I’ve used. I loved the blizzaks in stock size when I used them but they wore out WAYYY to quick
Old Dec 10, 2021 | 07:03 PM
930 Engineering's Avatar
930 Engineering
I have to agree with Jason and Nick. If you want to keep your 17" wheels anyway and tire choice
is your concern just go with 215/45 R17. Better choice than 205/45 and not that tall as 205/50 R17.
Still a bit heavy though. Personally I'm running 195/55 R16 during winter and will go 205/50 R16 next.
Old Dec 10, 2021 | 07:47 PM
Alexzannder
thanks I just looked into it and the 215/45 comes with the same studded options as the ones that I looked at. So that might be the tire size for me!
Old Dec 10, 2021 | 07:51 PM
Alexzannder
thank you, when I was talking to the tire shop they never mentioned that size. Looks like 215/45/17 is the way im going to try this year.
Crashway2many
R55 :: Clubman Talk (2008+)
Dec 24, 2014 04:35 AM
larmini
Tires, Wheels, & Brakes
11
Mar 14, 2014 04:39 PM
highlander709
26
Mar 28, 2013 08:12 PM
52804x4
Oct 24, 2012 05:10 PM
djafactor
Factory JCW Talk (2009+)
16
Jan 25, 2010 11:23 AM
