R55 Blow off valve?
Old Dec 7, 2021 | 03:55 PM
Bgolden20's Avatar
Bgolden20
Blow off valve?
So when I start my car in the morning it sounds like it’s sucking a lot of air then shuts off after a couple of seconds but the rpms are at like 1000 idk if it’s the blow off valve getting stuck then when it worms up it closes or a vacuum leak and befor the my car has been running a lil rough I have a 2014 r55
Old Dec 8, 2021 | 03:53 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Sounds like you are describing part of the cold engine start / warm up cycle. However, you haven’t stated if the car has any modifications? Are you running OEM diverted valve and intake? Or aftermarket parts?
Old Dec 8, 2021 | 09:27 AM
Bgolden20's Avatar
Bgolden20
I have a stock blow off valve and aftermarket air intake
Old Dec 8, 2021 | 09:31 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
From my experience, what you are describing sounds normal
Old Dec 8, 2021 | 11:13 AM
Bgolden20's Avatar
Bgolden20
I mean it’s to loud to be normal and then When I drive it it don’t sound right
Old Dec 8, 2021 | 11:29 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Is this still your current intake, or which aftermarket kit do you have?
https://www.northamericanmotoring.co...ml#post4604574
Going from a "Stock" intake to an aftermarket 'open' element intake, you will hear different sounds. The stock intake is very good at muffling intake noises.
Old Dec 8, 2021 | 11:51 AM
Bgolden20's Avatar
Bgolden20
I get there will be new sounds but it’s like a fan is in there lol and when I push on the gas a little bit it stops till I release from the gas the sound comes back idk it’s like the blow off valve is stuck open and when I push on the gas it pushes it closed maybe idk I will take a video so you can hear it
Old Dec 8, 2021 | 11:55 AM
Bgolden20's Avatar
Bgolden20
And I took the intake box out and put a pod filter
Old Feb 15, 2022 | 12:46 PM
JustinLaabs's Avatar
JustinLaabs
I have the M7 intake and when its a little chilly outside and the cold start is running at around 1,300 rpm that thing is sucking a lot of air and it is crazy loud and then once it drops to 900 its back to sounding normal
Old Feb 18, 2022 | 07:26 PM
Andrewsolis83's Avatar
Andrewsolis83
The OEM valves are trash anyways. Even on my wife's mild Countryman, it has a Turbosmart dual port. Wouldn't be a bad idea to upgrade it anyways if you are planning on running a stock, JCW or F21M turbo as they all use the same
Brandon Fluharty
Nov 14, 2021 12:47 PM
IndieJoe
Mar 26, 2017 12:30 PM
ViVi^BoY
Nov 3, 2007 10:46 PM
o-ron
Aug 9, 2006 01:08 PM
