R50/53 Bypass valve issue maybe?
Old Nov 9, 2021 | 04:27 PM
Brandon Fluharty's Avatar
Brandon Fluharty
I know this has been covered before but I can’t tell for sure if it’s the bypass valve or a vacuum leak because I’m building boost but mostly only at wot and I have a ac delete so it can’t be that but it has thrown the bypass sticking code before just not in the past month or two since I threw some white lithium grease on it the only thing that makes me think my valve is still messed up is sometimes the idle will get really choppy and rough
Old Nov 12, 2021 | 05:20 AM
nd-photo.nl's Avatar
nd-photo.nl
Could be that the diaphragm (rubber) in the bypass valve is torn, which could account for choppy behaviour. This is how it looks inside
Old Nov 12, 2021 | 08:04 AM
cooper48's Avatar
cooper48
Someone correct me if I'm wrong but I don't believe the BPV would cause a choppy/rough idle. Sounds more like a possible vacuum leak to me.
Old Nov 12, 2021 | 12:57 PM
ssoliman's Avatar
ssoliman
Could be many things
any dtc’s?
Old Nov 14, 2021 | 12:47 PM
ghostwrench's Avatar
ghostwrench
Following this thread. I too suspect I have a bypass valve issue as well, despite my having installed a new one in January when I replaced my supercharger. My symptoms are under partial throttle (normal acceleration), there is a very noticeable flat spot in power from about 3000 - 3500 RPM. If I got to WOT when I hit this flat spot, my car will respond with full power. This flat spot is REALLY irritating to me, it's like something is holding my car back.
I also get random, rough idling but that has existed for years and these forums indicate that is something with the electronic throttle, so I'm not very concerned about that.
godzilla
Nov 3, 2018 06:02 AM
IndieJoe
Mar 26, 2017 12:30 PM
Hochspannung
Mar 23, 2013 12:12 PM
ViVi^BoY
Nov 3, 2007 10:46 PM
regalic
Mar 17, 2005 04:54 AM
