Suspension Replace both??
Old Aug 3, 2021 | 05:27 PM
e24mpwr's Avatar
e24mpwr
Replace both??
My '10 Clubman Justa has crap rear camber alignment that won't even allow the best of one side to match the worst of the other side at -2.6°/-3.0°. So I've got H-sport rear lowers on order from Way (who was answering emails at 11:30PM BTW - wow).
The toe adjustment works fine, but I'm wondering whether I should replace the other pair too. I don't really want to bite off a second adjustable set, especially since the car is a daily that occasionally enjoys some spirited driving when possible, but not a track or autocross.
The alternatives are:
- leave the uppers alone
- replace the uppers with stock
Of course, I could replace the uppers with adjustables, but honestly I don't think I need that given the above, and Way didn't recommend it either.
Thoughts and insight welcome!
Old Aug 4, 2021 | 03:54 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Just leave the uppers. Unless you are tracking the car and need all the adjustment, or yours are bent from some freak accident, there is no need to replace the uppers, even with new OEM arms.
Old Aug 5, 2021 | 05:36 AM
thefarside's Avatar
thefarside
Why so much camber? If it were mine I'd like to get to root cause before applying a solution.
Old Aug 5, 2021 | 02:32 PM
Eddie07S's Avatar
Eddie07S
MINIs have a lot of camber in the rear... about -2 deg (I’d have to look it up to be sure). The -3 is way out.
Old Aug 5, 2021 | 06:04 PM
thefarside's Avatar
thefarside
Bentley lists 1.75 degrees max for the std. suspension. Further the OP states that neither side can be dialed down (at least I think that is what was meant).
Old Aug 6, 2021 | 06:32 AM
Eddie07S's Avatar
Eddie07S
Do you know if that is for the Clubman or the Hatch or both?
None the less, both sides of the car are way off.
Old Aug 6, 2021 | 10:29 AM
thefarside's Avatar
thefarside
According to Bentley the alignment specs are the same for all models. There is a variant of the sport suspension that is slightly different.
I assume that Mini dials in a lot of rear camber to increase understeer.
Old Aug 6, 2021 | 10:58 AM
Eddie07S's Avatar
Eddie07S
That is what I would have guessed for the camber setting...
As for “increase understeer” maybe a better way to put it would be “to lessen the propensity for oversteer”. Any of these cars can be made to oversteer, which is something that you don’t want to happen in these cars... In my R56 I have dialed in the max negative camber in the rear for the track just because I don’t want that to happen and to balance the added negative camber I have in the front. And, no, the car doesn’t understeer like crazy and can be made to oversteer.
Old Aug 6, 2021 | 11:22 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
As mentioned, increased camber in the rear to lessen the chance that the back end comes around on you. All modern Minis are spec'd to have more camber in the rear than the front, even the GP models. And the way the rear suspension is designed, when the car leans over, even more camber is gained in the rear. With such a short wheel base, you really don't want the rear to be too loose.
Old Aug 6, 2021 | 11:34 AM
Eddie07S's Avatar
Eddie07S
I hope you mean the camber moves to be more positive when the car leans... negative camber is lost... Which makes the car more dangerous...
​​​​​​​With such a short wheel base, you really don't want the rear to be too loose.
​​​​​​​Sooooo true!
Old Aug 6, 2021 | 11:48 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
As the suspension compresses, more negative camber is gained. Its built into the suspension design. The upper control arm pulls the top of the hub inward as it moves up, and the lower control arm pushes the bottom of the hub outward. I'm not sure what the actual gain numbers are, but that's what it does. That's why when you lower a Mini, it is recommended to get camber arms to bring the negative camber back into spec.
Old Aug 6, 2021 | 12:16 PM
Eddie07S's Avatar
Eddie07S
Body roll does more to remove negative camber than compression does to increase negative camber. Here is a picture from a Charlie Thompson post (link)
Charlie Thompson JCW estimated body roll 2.5 deg
As he explains in his post the body roll removes that amount of camber, which he estimates leaves him with about +0.4 deg of camber... his static front camber is -2.1 deg... Give how stiff these cars are, the rear will follow the front.
Compression or lowering the car only changes camber by a few tenths of a deg... The big winner here is body roll...
dboard7
Suspension
15
Apr 10, 2013 03:03 PM
Erhan
Suspension
Feb 16, 2012 04:58 PM
jtack
Suspension
Oct 12, 2008 03:04 PM
DancesWithCones
SCCA Solo and ProSolo
May 6, 2006 08:38 AM
Wiggles
Feb 26, 2005 10:39 AM
