R52 Conversion clutch kit Valeo trouble
Old Jun 14, 2021 | 12:29 PM
Pierfranco's Avatar
Pierfranco
Hello and sorry for my english.
I have a R52 S and I bought a Valeo Conversion Clutch Kit.
The problem is the crankshaft blocked after mounting the gearbox on the engine.
The gearbox is unlock before mounting
The engine is unlock before, also after new flywheel and clutch kit mounted.
But after bringing the gearbox closer to the engine and tightening the bolts, the crankshaft does not turn anymore.
Someone know why?
Old Jun 15, 2021 | 06:42 PM
jjcsnlynn's Avatar
jjcsnlynn
Are you sure you have the transmission input shaft lined up with the clutch plate? Did you have and use the alignment tool? Then I installed mine it was off and I had a hard time getting it to seat and align the disc.
Sounds like its not aligned correctly.
Old Jun 16, 2021 | 01:08 AM
Pierfranco's Avatar
Pierfranco
Thanks for answer, I wrong a stupid thing.
The clutch disc was to wrong side.
Old Jun 16, 2021 | 04:36 AM
jjcsnlynn's Avatar
jjcsnlynn
It happens. I’ve done that too. Glad you figured it out.
Old Jun 16, 2021 | 08:11 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Seen that happen before as the disc looks like it should go that way, but it's opposite what you think.
Old Jun 17, 2021 | 03:19 PM
Pierfranco's Avatar
Pierfranco
Guys I have other problem, the disc not engage.
​​​​​​It's possible that doesn't work because the monomass flywheel it's less height (8mm) then original dualmass?
I installed kit Valeo 835024, it's ok for 2004 R52 S?
Old Jun 18, 2021 | 08:05 AM
tophilious's Avatar
tophilious
Bump. I just did this kit when I went from a 5 speed to the getrag 6. I'm also at wits end here. Lol
Edit: this issue has been resolved
Last edited by tophilious; Sep 5, 2021 at 11:06 PM. Reason: issue not a problem anymore
Old Jun 18, 2021 | 10:41 AM
https://www.ecstuning.com/b-valeo-pa.../52151203~val/ R53/R52 S/JCW all years
or
https://www.ecstuning.com/b-valeo-pa.../c-drivetrain/ is the kits for the R52/R53 6speed 7/2004+ USA
Those are the ones for the cars 7/2004+
Make sure you have the correct kits.
yyj3869
Dec 14, 2017 07:03 PM
yyj3869
Nov 3, 2017 05:13 PM
Apr 26, 2017 12:38 PM
portedbuckle
Sep 20, 2012 09:03 PM
