Do I need to re-calibrate the TB after replacement?
Old May 27, 2021 | 08:25 AM
tjkru's Avatar
tjkru
I have had issues with an weak motor. It is throwing MAF codes. Cleaned the MAF sensor and was going to then replace it when that did not fix the issue. Was advised that the codes are actually likely to be the throttle body not opening as it should causing a lean and or rich condition. So I am going to replace that when the part arrives. Do I need to re-calibrate the throttle body after replacing it? I have a Foxtell 510 scanner, can this tool do that task?
Old May 27, 2021 | 11:03 AM
Jason Cornelius's Avatar
Jason Cornelius
From Haynes manual…
You are probably going to have to dig around on how to reset it. I’ll try to see what I can find on Newtis.
Old May 27, 2021 | 04:01 PM
cristo's Avatar
cristo
Alliance Member
Or just do this.
https://www.rpmmotorsport.net/pages/...aptation-reset
That’s what I did after swapping in
a new throttle body (2009 JCW Clubman)
and it worked perfectly.
Old May 27, 2021 | 04:03 PM
Jason Cornelius
Originally Posted by cristo
Or just do this.
From my searches I found this as well, I haven’t dug anything thing else up.
Old Jun 16, 2021 | 07:49 PM
Clockwork's Avatar
Clockwork
I just replaced my TB myself and called mymech and they told me to come by and they will reset my adaptations. I tried the reset based on the rpm website before i went to my mech, but I never noticed a change as much as when my mech did the reset. I then let the car idle for 5 mins, it wassooooooo smooth.
Gabe3
Oct 20, 2020 08:48 AM
clammy77
Jan 3, 2019 07:44 PM
midacl
Jan 15, 2014 04:55 PM
Nelson Costa
Aug 4, 2013 12:37 PM
wakxed
Jul 26, 2013 06:50 PM
