Do I need to bleed cooling system for
Old May 2, 2021 | 08:09 AM
ditc's Avatar
ditc
I need to loosen and possibly take off the banjo bolt that holds the coolant tube to the turbo (moving it out of the way in order to get access to the diverter valve on my N18).
In this case would I need to bleed the entire cooling system once I reattach it ?
thanks
Old May 2, 2021 | 11:17 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
When I removed my diverter valve, I only removed the bracket bolt that holds the water line to the compressor housing, above the intake tube connection. Just removing that bolt allowed for enough flexibility in the water line to get the diverter valve out. Then, just line up the bolt and bracket, and reinstall when done.
Old May 2, 2021 | 03:18 PM
ditc's Avatar
ditc
Thanks for the tip, good to know. I was anticipating having to remove the whole thing.
Old May 2, 2021 | 03:52 PM
Jason Cornelius's Avatar
Jason Cornelius
I just took mine out today chasing down an issue, I just loosened the coolant tank from its mounts and let it sit down in that hole loose. Gave enough play in the coolant hose to move up and down.
Old May 4, 2021 | 05:08 PM
ditc's Avatar
ditc
Well unfortunately, I have had to remove the banjo bolt to remove the hardline for coolant to the turbo in order get access to the bolts holding the DV in. Removing the bracket bolt didnt really do anything as far as being able to move it out of the way. It’s different on the N18 with the hardlines and hoses and there is just no room unless you have a 4-5” long and thin 5mm Allen wrench and some sort of ratchet attachment.
Old May 4, 2021 | 05:12 PM
Jason Cornelius
I have a set of Torx head screw drivers and I think it was a t25 that did it. They are your average length and fit right in there.
Old May 4, 2021 | 06:32 PM
Gubi's Avatar
Gubi
Well, I dunno what to tell you, but I was able to replace the diverter valve on my N18 2012 without removing any coolant lines. I think I just removed the big intake hoses and moved the coolant tank out of the way.
Old May 5, 2021 | 03:35 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I also was able to change mine on my N18.
Your toolbox needs a set of these:
https://www.harborfreight.com/38-in-...-pc-67888.html
Old May 5, 2021 | 03:45 AM
Jason Cornelius
Amazon Amazon
and a set of these…I can’t tell you how many times I have used these.
AndrewVanis
May 18, 2020 07:26 PM
corliss hale
Oct 5, 2016 06:13 AM
Phil Foster
Sep 7, 2016 08:02 AM
Catch_Me
Jun 30, 2015 08:45 AM
ArmyDog
Aug 8, 2006 08:32 AM
