R50/53 HELP! No start?
Old May 1, 2021 | 12:31 PM
alconk's Avatar
alconk
HELP! No start?
I just replaced my cam in my 05 R53 but forgot to release the chain tensioner so when I started it chain jumped off and sheared the cam sensor. Bought a new chain and replaced and timed by the book. Got everything buttoned back up and excited to start but now it won’t. Checked the codes and came back as a po341 cam sensor. Pulled it back apart to check again and everything looks good. I checked the new cam sensor with another by a multimeter and both were the same. What has happened?
Old May 1, 2021 | 02:18 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Did you make sure you put the cam gear back correctly. As in backwards?
Old May 1, 2021 | 03:37 PM
alconk's Avatar
alconk
the arrow is pointing outward unless there’s an arrow on both sides?
Old May 1, 2021 | 05:52 PM
alconk's Avatar
alconk
I had it in correctly but can these scratches cause a low input for the cam sensor?
Old May 1, 2021 | 07:29 PM
alconk's Avatar
alconk
Well put everything back together with a different new cam sensor and nothing no start. Comes back with the same po341 cam sensor measuring range??
SKI-R
Apr 21, 2017 01:08 PM
Why me
Mar 21, 2015 08:00 PM
Joeygonz
Oct 2, 2014 12:01 PM
gear
Apr 22, 2014 10:28 AM
SniperDetailing
May 20, 2013 12:45 PM
